Results 1 to 9 of 9
Thread: Stand up radiator
09-09-2017, 02:13 PM #1Lurker
- Dec 2012
- Tommy N.
- Silver 1996 Camaro Z28, Green 1996 Camaro Z28
- El Paso, TX
- 946
Stand up radiator
What's a good brand of stand up radiator to get looking to get one since the engine I have is going to have a supercharger, and I would like to have a stand up radiator instead of the slanted style I did some searching in the forum and I read that the oem will work just fine but I like the way the stand ups look.
Sent from my iPhone using Tapatalk96 Camaro Z28 Silver Mostly Stock, Full Exhaust
09-09-2017, 02:24 PM #2Lurker
- Sep 2014
- Joel
- Colorado
- 1,157
Following
09-09-2017, 06:16 PM #3Xtreme Member
- 7,249
09-14-2017, 10:28 AM #4LTX Master
- Nov 2013
- Corey
- 94 Camaro z28
- new hampshire
- 575
09-14-2017, 11:58 AM #5
I doubt you will find any method of standing radiator vertical without cutting of either top support or bottom support.
I looked at doing it on my car and I determined it was going to be a lot of work with very little gain. The biggest gain, is you can run factory puller fans with shroud similar to OEM. But, I have had no issue with two quality pusher fans and no shroud.
IMO, put the money elsewhere.Correlation does not imply causation.
09-18-2017, 10:51 PM #6Lurker
- Sep 2014
- Joel
- Colorado
- 1,157
Does any on have photos of the stock Radiator stood up in an Fbody.
Sent from my QMV7A using Tapatalk
09-19-2017, 08:33 AM #7Correlation does not imply causation.
09-19-2017, 08:45 AM #8Xtreme Member
- Nov 2008
- Chris
- 1994 Trans Am
- PA, USA
- 2,438
My Griffin rad is standing up, no cutting required. Two brackets were welded to the upper support to lock it in place. I have the option of cutting the upper to slam a turbo up front if need be.
Now you're probably wondering part numbers for everything. Honestly, I don't remember. I bought the spal fan and rad setup used locally.
09-19-2017, 04:56 PM #9LTX Master
- Aug 2013
- JB
- Atoka,TN
- 531
That's the way to go. I can't believe the room between the electric water pump and fans. That looks like the same clearance an impala has. Nice setup.
Sent from my SAMSUNG-SM-G900A using TapatalkSame as everybody else...350 small block, double hump heads, 3/4 cam
The Following User Says Thank You to Cathead For This Post:
