Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 41
  1. #11
    The FABRICATOR!
    Jul 2011
    southern illinois
    Quote Originally Posted by BALLSS View Post
    if a Carb motor now.....you don't want to run the stock fuel pump. You only need about 4-5 PSI for a carb motor. stock LT1 FP will not work
    So whatever pump you do buy, it should tell you amp draw...and I would wire through a relay/fuse
    Pumps don't make pressure, resistance to flow does. The pump moves a volume of fuel, the fuel pressure regulator restricts flow as needed to maintain pressure.
    Troy, in your other thread a while back I posted about the max amps. At 5 psi it was going to be around 4 amps by the chart I found. I would set your regulator at 8# and check the amp draw if you can, then size the circuit based off of that. You shouldn't ever need 8# of pressure but some carbs can like up to 7.5# depending on how they're set up
  2. The Following User Says Thank You to firebird_1995 For This Post:
  3. #12
    You will just end potentially heating up your fuel by making it constantly go through the pump with such a large volume pump. But it will work
  4. The Following User Says Thank You to shownomercy For This Post:
  5. #13
    run a relay. why are you trying to a) reinvent the wheel and b) be sloppy as hell/dangerous
  6. #14
    The Nitrous Outlet Junkie
    Apr 2010
    Troy
    moore, ok (south okc)
    It's not sloppy or dangerous it's a fused circuit and the fuse I have in place is not enormously oversized if anything goes wrong it'll pop the fuse and turn off the pump
  7. #15
    it's sloppy/hackjob, it should be a relayed circuit, what part of anything anyone has said here don't you understand? a switch is not designed to carry a load constant like that. also, a fuse pops at 80% of its rated capacity. fuses don't always pop quick enough even when sized properly, so wiring can melt as well.
    a relay is $2, and a few extra crimp connectors. cheap insurance to protect your switch and other things. if the time and effort to do it right is too much, don't do it.
    I've built cars being broke, shit I'm still broke. I'm captain zip tie, the rtv king, and I love crimp connectors. but there's things I won't hack, like using proper circuits in wiring systems, wire size, fuses, relays, etc. c'mon man.
  8. #16
    LTX Regular
    Aug 2013
    Gary
    1998 Trans Am
    Florida
    Here, here! As an electrical engineer, this is what I like to hear. Good on you.
  9. The Following User Says Thank You to GaryDoug For This Post:
  10. #17
    Apr 2010
    Troy
    It will work fine
  11. #18
    Quote Originally Posted by GaryDoug View Post
    thank you
  12. #19
    It will work fine
    Does that mean ur still gonna go against the advice given to u?
  13. #20
    Apr 2010
    Troy
    No I am taking it all in consideration ... I've had some people tell me it's fine, some people tell me I need a relay some, people tell me I need to put the PCM back in simply to run the fuel pump. ...
