Results 41 to 41 of 41
Thread: Fuel pump amp draw
09-07-2017, 09:05 AM #41
Wow, this thread really blew up...lol.
Anyway, not using a relay is your choice depending on your risk tolerance level. I do not run a relay on a few intermittent use things in my car (line lock, trans brake, and purge) as the risk of failure is low due to their infrequent use. I would be worried of a switch failure or something failing in the circuit that would leave me stranded, or trouble shooting at the track, or going down the track and causing the engine to starve of fuel. All the risks could also happen with a relay but the probability is lower than with a manual switch failure. In the end, it is your choice and your risk tolerance level.
BTW, the switch panel looks awesome!
The Following User Says Thank You to Nostang 96z For This Post:
