Results 1 to 10 of 25
Thread: Thermostat delete or keep
08-31-2017, 11:54 AM #1The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 1994 Firebird Formula
- moore, ok (south okc)
- 3,274
Today I I'm working on the electrical part of the car and replacing a fuel pressure gauge with water temperature gauge. Which got me to thinking about water temperatures for my car and how hot I think it will really get. With this car being carbureted instead of fuel injected that might have a factor in my decision but ultimately a cooler motor will make more horsepower. So for being a car that's not going to see extensive driving on the streets like cruises or road trips mainly going to be drag racing do I really need to run a thermostat? ... the vehicle has an electric water pump some people were talking about restrictor plates as I was reading. I'd like for some of y'all to weigh in on this please.
08-31-2017, 11:56 AM #2Xtreme Member
- 7,249
08-31-2017, 11:59 AM #3The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 3,274
08-31-2017, 12:01 PM #4Xtreme Member
- 7,249
08-31-2017, 12:03 PM #5Xtreme Member
- Mar 2015
- Mike Storm "Stormy"
- 1995 Trans Am
- Washington
- 1,020
- Blog Entries
- 1
Never run anything without a thermostat. There shouldn't be any debate. Just run a cooler one. It's like a traffic cop sort of for your cooling system.
08-31-2017, 12:04 PM #6The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 3,274
Okay so I definitely need something in there I saw some people talking about restrictor plates would I be able to use one of those
08-31-2017, 12:17 PM #7
A cold motor doesn't always make more power than a correct temperature one either.
Run a 160/180* statCorrelation does not imply causation.
08-31-2017, 12:24 PM #8The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 3,274
I had a 160 in it before and it ran about 180 ... I would always get a little nervous when it ran 200 plus as it approaches the boiling temperature of water it just makes me nervous
08-31-2017, 12:29 PM #9Xtreme Member
- 7,249
08-31-2017, 12:55 PM #10
Zoo
run a 160 stat and have PCM programed to turn on fans lower than stock temp
if your motor is Carb now and not using a PCM than just get a inline temp switch to turn fans on at desired temp
but run a stat. you can buy ones that fail "open"96 BBB 383/T56
