Results 1 to 8 of 8
Thread: Radiator options
07-17-2017, 05:53 PM #1The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 1994 Firebird Formula
- moore, ok (south okc)
- 3,274
Radiator options
The car is coming back together nicely and I've got the motor in the car. one thing I remember is how crowded it was in front of the motor with all the hoses. I have plugged the ports where the hoses for the heater core would go on yhe water pump. that leaves me with three remaining lines two large and one small. I would really prefer to just have the two large hoses eliminating the small one however that would leave an open port on my radiator and it wouldn't utilize the entire cooling area. What different radiators and or hoses have you guys used making a little simpler up front.
07-17-2017, 07:50 PM #2Xtreme Member
- 7,266
Supporting Memberstock radiator, with a cap over the oil cooler feed line port.....it doesn't decrease cooling capacity.....it would actually increase the flow in and out of the main port of the rad by a miniscule amount, since that little port won't be a pressure drop anymore
07-18-2017, 01:23 PM #310 Second N/A Club
- Josh
- 96 Z28
- Holden, MO (KC)
- 2,867
Just using the large inlet and outlet on the WP and radiator here.
-Josh
co-owner of BDBRacing.com
NMCA OC 9004
The Following User Says Thank You to 96LT1355Z28 For This Post:
07-27-2017, 08:58 PM #4The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 3,274
So are y'all telling me I don't have to hook that line up to anything and it won't leak because if I can delete that hose I would like to
07-28-2017, 04:39 AM #5Xtreme Member
- 7,266
07-28-2017, 05:17 AM #6The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 3,274
So just take it off or plug it somehow ?
07-28-2017, 12:10 PM #7Xtreme Member
- 7,266
07-28-2017, 02:54 PM #8LTx Guru
And do the same thing with the connection on the water pump.
http://shbox.com/1/93-94_hoses.jpgSOLD - GONE TO A (VERY) GOOD HOME ! - 94 Formula A3+1: 381ci forged stroker - Callies Stealth, Oliver 5.85 billet rods, BME nitrous pistons / CNC LT4 heads / CC solid roller / TH400+GearVendors OD / 4.11 Strange 12-bolt / 300-shot N2O / Spohn Suspension / roll bar / MoTeC M48 Pro engine management system /a few other odds 'n ends.
