Results 21 to 28 of 28
Thread: How do I turn on my fuel pump
07-23-2017, 08:53 PM #21The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 1994 Firebird Formula
- moore, ok (south okc)
- 3,274
I no longer have a PCM in the car so all I have is the relay and wires .... do I need to put 12 volts to both pink and the dark green / White
Sent from my SM-N910T using TapatalkLast edited by zooguy; 07-23-2017 at 08:57 PM.
07-23-2017, 08:54 PM #22The FABRICATOR!
- Jul 2011
- Chris
- 1985 Monte Carlo SS
- southern illinois
- 7,164
Do you still have the pcm wiring harness?
07-23-2017, 08:55 PM #23The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 3,274
The engine harness is no longer in the car but the body harness still is
07-23-2017, 09:02 PM #24The FABRICATOR!
- Jul 2011
- Chris
- southern illinois
- 7,164
If the connectors on the shock tower are still there you can access the relay wiring there. Otherwise, you will need to supply the pink wire with fused +12v power for the fuel pump supply, and the green/white with +12v power from your switch of choice
07-23-2017, 09:03 PM #25The FABRICATOR!
- Jul 2011
- Chris
- southern illinois
- 7,164
http://shbox.com/1/harness_connector_faces.htm
07-24-2017, 11:27 AM #26The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 3,274
07-24-2017, 01:48 PM #27
Maybe I am missing something here, but why do you care at all about factory wiring if you are missing half of it, and are planning on using a switch panel?
Run clean new wiring and sketch a schematic for the car.Correlation does not imply causation.
07-24-2017, 04:02 PM #28The FABRICATOR!
- Jul 2011
- Chris
- southern illinois
- 7,164
Click c220 at the bottom
