Page 1 of 2 12 LastLast
Results 1 to 10 of 17
    Mar 2017
    Britt
    1994 Camaro Z28
    South Florida
    Default Best Radiator Replacement
    My oem radiator has a slight crack and is leaking very subtly so looking to get a new one. Anyone have a preference in brand? I'm running the 24x ignition system but not planning on modding anything else
    1994 Camaro Z28 l 5.7L V8 6-speed manual l 45K original miles l LT1 to LS1 coil conversion (LTCC) l Magnaflow Exhaust
    Mar 2017
    Britt
    1994 Camaro Z28
    South Florida
    http://www.protuninglab.com/j2-008.html
    Looking at this one but would like to spend a little less if I can
    Aug 2016
    Dan H
    1995 LT1 Caprice
    What's wrong with stock? Or take yours in to the local shop and have it re-cored / repaired
    Mar 2017
    Britt
    1994 Camaro Z28
    South Florida
    Nothing wrong with stock but figured if I'm replacing it, might as well upgrade. Local shop said a jb weld won't do
    Quote Originally Posted by camz2894 View Post
    fact is the stock lt1 radiator has great cooling capacity. we kept it in the 383 procharged car, no need for anything aftermarket unless you wanna look pretty. $100 at advance, always in stock, idn why people get these super expensive be cool etc rads
    Mar 2017
    Britt
    1994 Camaro Z28
    South Florida
    Yea the only reason why I would upgrade is to get the aluminum tank instead of plastic to avoid the cracking. But not sure if the price justifies that. The radiator in there now is the original radiator from 23 years ago lol
  7. The Following 2 Users Say Thank You to camz2894 For This Post:
  8. #7
    if it lasted 23 years, it should last atleast 10 now lol. best of luck. and the ltcc is working great thanks.
  9. The Following User Says Thank You to SSlowBoat For This Post:
  10. #8
    Mar 2017
    Britt
    1994 Camaro Z28
    South Florida
    Thx, Great! Glad it's working for you
  11. The Following User Says Thank You to camz2894 For This Post:
  12. #9
    Apr 2012
    Cameron
    Dover, De
    Another vote for stock.
    Formula Build Thread
  13. The Following User Says Thank You to Sahara54 For This Post:
  14. #10
    Apr 2012
    Mike
    96 Z28, 95 Roadmaster
    Conshohocken, PA
    I have a parts store one on mine. Just make sure they're the same thickness as stock because the later LS rads are thinner. Not sure if mine has a trans cooler built in but I don't think so.
  15. The Following 2 Users Say Thank You to Catmaigne For This Post:
