Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. #11
    Jun 2015
    Ryan
    1994 Camaro Z28
    Minnesota
    Just go stock, recoreing one isn't worth the $$$$$ IMO
    94 Z28 - 396 - TH400 - 9in - SLOW
  2. The Following 2 Users Say Thank You to agenthol302 For This Post:
  3. #12
    Cameron
    Dover, De
    I have a parts store one on mine. Just make sure they're the same thickness as stock because the later LS rads are thinner. Not sure if mine has a trans cooler built in but I don't think so.
    Sent from my VS986 using Tapatalk
    This ^ ...93-96 are 1 1/4" and 97 up are 3/4. The LT is an upgrade for LS cars.
    Formula Build Thread
  4. The Following 3 Users Say Thank You to Sahara54 For This Post:
  5. #13
    Mar 2009
    Spring, TX
    It cost me $65 for a radiator shop to replace my cracked side tank, way less than a quality replacement.
  6. The Following User Says Thank You to Spartan7 For This Post:
  7. #14
    Mar 2017
    Britt
    1994 Camaro Z28
    South Florida
    Quote Originally Posted by Spartan7 View Post
    Hm didn't think of this. I'll look into that.
    1994 Camaro Z28 l 5.7L V8 6-speed manual l 45K original miles l LT1 to LS1 coil conversion (LTCC) l Magnaflow Exhaust
  8. The Following User Says Thank You to camz2894 For This Post:
  9. #15
    Nov 2009
    Desert, so cal
    I would just get a stock replacement. I did about 8 years ago and it's been great.
  10. The Following User Says Thank You to NoMoneyZ For This Post:
  11. #16
    I run a stocker in mine, seeps a lil but its only water so whatever.
    A custom would have been nicer; I could run a solid fan shroud and have it mounted with solid mounts, but, OE was cheap and I had it.
  12. The Following User Says Thank You to shownomercy For This Post:
  13. #17
    1994 Trans Am
    PA, USA
    I love my Griffin/spal setup. If I didn't get such a good deal on it (used), I would have kept the stocker or picked up a Napa or Summit drop in replacement. I picked up a drop in Summit rad for my 3rd gen and was very impressed with it.
  14. The Following User Says Thank You to harner For This Post:
