Page 1 of 2 12 LastLast
Results 1 to 10 of 16
    Sep 2014
    Joel
    Colorado
    Default Data Logging software for OBDll
    Looking to see what everyone is using for data Logging software for OBDll equipped cars.
    Aug 2015
    Braxton
    1996 ws6 trans am
    Also needing advice? Thanks
    Oct 2015
    Drew
    1996 M6 Z28
    Oklahoma
    I would like to find something myself. I know people used to recommend Autotap but they are no longer in business. On other forums I've seen people say HPTuners VCM scanner works but according to their website OBD2 LT1 cars are not on the supported vehicles list. I have never called them to find out. Their scanner is more expensive than doing an OBD1 conversion and getting the software to datalog and tune it so I figure I will go that way some day.
    1996 Z28, M6, T-tops, stock rear, LE stock ported heads (not typical LE stage, it's a friend of a friend deal), Custom cam and tune from JimTune, CR 11.1, Pacesetter LT, Ram Powergrip HD, flowmaster original 40, Eiback prokit, 18" corvette black wheels from ebay, meizere electric w/p, relocated battery to spare tire well, dd with AC Delco Opti.
  4. The Following User Says Thank You to okst8engineer For This Post:
  5. #4
    Sep 2014
    Joel
    Colorado
    I have been do some research on data Logging software. I have found a couple.
    http://www.auterraweb.comwww.auterra...auterraweb.com
  6. #5
    Sep 2014
    Joel
    Colorado
    The other software I have found is OTC 3005 data Logger
  7. #6
    Aug 2015
    Braxton
    1996 ws6 trans am
    Thanks. It's not expensive either. I wonder if it will log the long term fuel trim?
  8. #7
    Mar 2009
    Spring, TX
    I've looked into it quite a few times, and it seems like ScanXL Pro with their optional GM enhanced PID's may be the way to go. It's a little pricey though, but there's not much out there for us poor OBD2 guys.
    https://ls1tech.com/forums/lt1-lt4-m...a-logging.html
    https://www.scantool.net/scanxl-pro/
  9. #8
    Oct 2015
    Drew
    1996 M6 Z28
    Oklahoma
    I just found this. I haven't tried it yet but I've seen injuneer say he likes this guy's 9495 datalogger and this is the same author. Might be worth a shot. Anyone else ever try it?
    http://www.ls1lt1.com/forum/4th-gen-...gram-free.html
  10. The Following User Says Thank You to okst8engineer For This Post:
  11. #9
    Mar 2009
    Spring, TX
    Scan9495 doesn't work for OBD2, unfortunately. And he has no plans to implement support AFAIK.
  12. The Following User Says Thank You to Spartan7 For This Post:
  13. #10
    Sep 2014
    Joel
    Colorado
    Quote Originally Posted by Spartan7 View Post
    @Spartan7 thanks you for your input. @Morehorsepower
