Results 1 to 10 of 16
Thread: Drivability issues.
07-11-2017, 02:00 AM #1Xtreme Member
- Mar 2015
- Dan Dalessandro
- 1997 Camaro Z28
- 2,211
Drivability issues.
I've been having some drivability issues for the past couple weeks. It seems to have started since I soaked the intake in water way back in March. After all that happened, I replaced the filter, cleaned the MAF, changed fuel pump to Walbro 255 and changed O2 sensors. It seemed to be better after all that.
Car is 24x swapped, 223/231 cam, manual.
Basically, the car will go lean when the gas pedal is pushed after not being pressed, but only for a split second and it'll go back to normal and deliver power. No codes other than EVAP.
Is this just a 24x thing, or a tune related issue? Still on my mail order tune from Moe.
Thoughts?
14.307@98.21, 2.155 60'
07-11-2017, 06:26 AM #2
The Following User Says Thank You to MoeHorsePower For This Post:
07-11-2017, 09:10 AM #3Lurker
- Jun 2015
- Ryan
- 1994 Camaro Z28
- Minnesota
- 372
how much water are we talking
07-11-2017, 10:22 AM #4Xtreme Member
- Mar 2015
- Dan Dalessandro
- 1997 Camaro Z28
- 2,211
07-11-2017, 04:24 PM #5LTx Guru
How does the voltage look at the TPS sensor, rotating the blades from closed to WOT? Does the voltage increase smoothly, with no dropouts or spikes?
Do you have a good, tight, no-leak connection from the MAF sensor to the throttle body..... no loose clamps, no tears in the rubber, rubber fully over the throttle flange, particularly at the bottom?SOLD - GONE TO A (VERY) GOOD HOME ! - 94 Formula A3+1: 381ci forged stroker - Callies Stealth, Oliver 5.85 billet rods, BME nitrous pistons / CNC LT4 heads / CC solid roller / TH400+GearVendors OD / 4.11 Strange 12-bolt / 300-shot N2O / Spohn Suspension / roll bar / MoTeC M48 Pro engine management system /a few other odds 'n ends.
07-11-2017, 10:51 PM #6Xtreme Member
- Mar 2015
- Dan Dalessandro
- 1997 Camaro Z28
- 2,211
07-12-2017, 07:19 AM #7
Did you clean the IAC ?
07-12-2017, 07:47 AM #8Xtreme Member
- 7,266
Supporting Memberif the filter got wet enough, and you got some droplets to hit the maf, the maf is shot. had this happen with a cai on my focus back in the day. filter got snow on it, snow melted soaking filter, a few droplets hit maf, car would run but not run right
07-12-2017, 03:59 PM #9Xtreme Member
- Mar 2015
- Dan Dalessandro
- 1997 Camaro Z28
- 2,211
07-12-2017, 04:28 PM #10Xtreme Member
- 7,266
