Results 1 to 7 of 7
06-16-2017, 08:48 AM #1LTX Member
- Jul 2015
- Nathan
- 1996 Camaro Z28
- North St Paul, MN
- 23
Speedometer, PCM and GPS all different
I didnt see anything similar in a search. I have 3.23 gears. when I bought the car the speedometer was about 10% off. I figured the car has different gears. Did some math and figured it has 3.42. It doesn't... I put the 3.23 gears back into PCM and its back to being about 10% off. last night I did a quick side by side by side comparison. I set the cruise at 70 per the speedometer. I plugged in the laptop to see that the PCM was reading for speed vs. the speedometer. For kicks and giggles I had the GPS running as well. What I ended up with has me even more perplexed. with speedo reading 70, the PCM was bouncing between 65 and 66 and the GPS was a steady 62. What the hell? anyone else ever run into this? any ideas on how to calibrate everything? I'm stumped.
06-16-2017, 09:38 AM #2Xtreme Member
- 7,249
06-16-2017, 10:11 AM #3
06-16-2017, 11:06 AM #4LTx Guru
- 2,279
The PCM drives the speedo, so any difference between the PCM reading and the speedo would likely be a problem with the speedo, converting the pulse count from the PCM to a physical movement of the needle.
Assuming the PCM value reads 65.5 MPH (average of values you observed) and the GPS values of 62 MPH is correct, the PCM error is 5.6% higher than actual. Having 3.42 gears in the rear, and 3.23 in the PCM would cause the PCM to read 5.9% high (not 10%). Pretty close.
What trans - auto or manual? If auto what led you to assume 3.42?SOLD - GONE TO A (VERY) GOOD HOME ! - 94 Formula A3+1: 381ci forged stroker - Callies Stealth, Oliver 5.85 billet rods, BME nitrous pistons / CNC LT4 heads / CC solid roller / TH400+GearVendors OD / 4.11 Strange 12-bolt / 300-shot N2O / Spohn Suspension / roll bar / MoTeC M48 Pro engine management system /a few other odds 'n ends.
06-16-2017, 11:17 AM #5Long Live the Opti
- Sean
- 1999 Twin Turbo Corvette
- Fort Wayne, IN
- 12,072
The Following User Says Thank You to Fastbird For This Post:
06-16-2017, 12:18 PM #6Xtreme Member
- Mar 2015
- Mike Storm "Stormy"
- 1995 Trans Am
- Washington
- 1,020
- Blog Entries
- 1
I take the difference between the three and drive (set my cruise control to 2 above the speedo) cause the PCM is told by the sender in the trans and tire size is a factor.
07-10-2017, 03:10 PM #7LTX Member
- Jul 2015
- Nathan
- 1996 Camaro Z28
- North St Paul, MN
- 23
***UPDATE***
I sent all of that info to Solomon, and he gave me a tune to correct it. Speedo, PCM and GPS all match. All shift issues are gone.
I had factory tire and wheels on when everything was askew. I didn't ask Solomon for the details of what he changed, I was just happy it was working. The difference was causing driveability issues at WOT. It would no shift 1-2, until I lifted off throttle, and shift flare from 2-3. All of that was gone with whatever Solomon did.Last edited by BSonoma; 07-10-2017 at 03:40 PM.
