Results 31 to 40 of 40
06-15-2017, 07:44 PM #31LTx Guru
The chart shows 4.78mm for all lines except the line to the rear brakes. 3/16" is 0.188", which is 4.76mm.
Rear line (6.00mm) use 1/4" = 0.25" = 6.35mmSOLD - GONE TO A (VERY) GOOD HOME ! - 94 Formula A3+1: 381ci forged stroker - Callies Stealth, Oliver 5.85 billet rods, BME nitrous pistons / CNC LT4 heads / CC solid roller / TH400+GearVendors OD / 4.11 Strange 12-bolt / 300-shot N2O / Spohn Suspension / roll bar / MoTeC M48 Pro engine management system /a few other odds 'n ends.
06-15-2017, 07:49 PM #32LTx Guru
Thread adapters:
http://www.oreillyauto.com/site/c/se...ts=20&sortBy=1SOLD - GONE TO A (VERY) GOOD HOME ! - 94 Formula A3+1: 381ci forged stroker - Callies Stealth, Oliver 5.85 billet rods, BME nitrous pistons / CNC LT4 heads / CC solid roller / TH400+GearVendors OD / 4.11 Strange 12-bolt / 300-shot N2O / Spohn Suspension / roll bar / MoTeC M48 Pro engine management system /a few other odds 'n ends.
06-15-2017, 08:04 PM #33The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 1994 Firebird Formula
- moore, ok (south okc)
- 3,274
Haven't attached the kit to the cars lines yet but there is the install
Got too hot in the garage. ... I'll finish tomorrow
06-15-2017, 08:06 PM #34The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 3,274
The kits instructions are lacking I had to go online and look at some pictures but once I saw it installed it was easy to put together
06-16-2017, 11:18 AM #35Long Live the Opti
- Sean
- 1999 Twin Turbo Corvette
- Fort Wayne, IN
- 12,072
06-20-2017, 07:18 PM #36The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 3,274
Done
06-25-2017, 07:43 AM #37VIP Member
- Dec 2011
- Mark
- Altoona, PA
- 809
Here's how I did my kids. Hurst line lock and Wilwood proportioning valve on rear brakes. Made a bracket to mount line lock near master cylinder. Will be doing mine next.
The Following 2 Users Say Thank You to 1QUICKZ28 For This Post:
06-25-2017, 07:59 AM #38VIP Member
- Dec 2011
- Mark
- Altoona, PA
- 809
You can increase the pressure to the rear brakes with the unit you bought. This may help balance out the brakes so front aren't as grabby. Other option is to install a single adjustable proportioning valve to the front wheels to dial the pressure down a little.
08-30-2017, 03:31 PM #39The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 3,274
Bump .... I'm stupid ... so I'm at a point now where I'm wiring up several things on the car and I've lost the instructions on how to correctly wire the solenoid ... does anybody have a diagram
08-30-2017, 09:13 PM #40LTx Guru
https://static.summitracing.com/glob...745000(2)1.pdf
Wiring is at the very bottom.SOLD - GONE TO A (VERY) GOOD HOME ! - 94 Formula A3+1: 381ci forged stroker - Callies Stealth, Oliver 5.85 billet rods, BME nitrous pistons / CNC LT4 heads / CC solid roller / TH400+GearVendors OD / 4.11 Strange 12-bolt / 300-shot N2O / Spohn Suspension / roll bar / MoTeC M48 Pro engine management system /a few other odds 'n ends.
