Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 40
  1. #21
    Shoebox has a chart of brake line end connections. Also identifies the approximate length of each stock line.
    I personally would have someone make the lines for me. The factory stuff, in addition to being metric, uses a GM "bubble" flare. Or maybe there are adapter fittings.... I don't know. My ABS stuff is still intact. I have a line lock in the line from the MC to the stock combination valve (on the side of the ABS).
    http://shbox.com/1/brake_pipes_frt.jpg
  2. The Following User Says Thank You to Injuneer For This Post:
  3. #22
    Quote Originally Posted by Formula218 View Post
    I've got this Wilwood from summit, I didn't know what one i needed so i got the one that seemed like it did the most stuff lol. Goals were to get rid of the giant ABS block and be able to add line lock eventually. WIll this do that?
    https://www.summitracing.com/parts/w...stionsanswers/
    Can any of you pros point me to a good install instruction for our cars as to what lines go to what ports? I'd love to dial back the pressure in the front just a hair now that i've got the V brakes.
    Attachment 37766Attachment 37767
    that's the one I will be using and @Fastbird used on his trans am
  4. #23
    Sep 2012
    Chris P. Bacon
    Lansing MI
    @Fastbird, have any pics of your install?
    '94 Formula 6spd
  5. #24
    Long Live the Opti
    Sean
    1999 Twin Turbo Corvette
    Fort Wayne, IN
    Unfortunately it never saw duty on my T/A. Parted the car before I ran it. I liked this kit because of the clean look and simplicity for installation.
  6. The Following User Says Thank You to Fastbird For This Post:
  7. #25
    Long Live the Opti
    Sean
    Fort Wayne, IN
    It was gnarly, was trying to work with a limited amount of free space away from the down pipe from the turbo.
    Broke through in the drivers wheel well, ran a single line around to passenger side.
  8. The Following User Says Thank You to Fastbird For This Post:
  9. #26
    quick question, what about the fittings at the flex line end? since I'm assuming u used standard sized line, isn't the fitting at the flex hose for metric line?
  10. #27
    Sep 2012
    Chris P. Bacon
    Lansing MI
    Thank you, i really like that mounting location. I think i'm going to ditch the ABS block location and just make some new lines to put it someplace cleaner.
    '94 Formula 6spd
  11. #28
    Long Live the Opti
    Sean
    Fort Wayne, IN
    I believe those fittings were an M10x1.0 which are available at your big box stores. Autozone sold them in 5 packs, used to be about $3.50 a pack, threw me for a loop when they jacked the price to $10 a pack recently.
  12. The Following User Says Thank You to Fastbird For This Post:
  13. #29
    but you can use that fitting on sae hardline?
  14. #30
    Long Live the Opti
    Sean
    Fort Wayne, IN
    Yeah, 3/16 and 4mm are nearly identical in size. There's more of a difference in 1/4" and 6mm (I have to drill my metric fittings out some to fit the available 1/4" lines I use).
  15. The Following User Says Thank You to Fastbird For This Post:
