Results 1 to 10 of 40
06-06-2017, 10:33 PM #1The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 1994 Firebird Formula
- moore, ok (south okc)
- 3,274
Proportioning valves and line locks
The car is coming together little by little getting All the Small Things buttoned up I deleted the ABS out of the car so now I need to run a proportioning valve what are the different options available and is there somebody who incorporates a line lock
06-07-2017, 12:37 AM #2
I don't know if it will help or Not, but I bought a SJM ABS delete kit that came with a line lock and Wilwood proprtioning valve.
The Following User Says Thank You to The Batman For This Post:
06-08-2017, 07:36 AM #3
I have this one in my new Camaro project but no line lock. https://www.summitracing.com/parts/sum-760185
06-08-2017, 12:52 PM #4The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 3,274
06-08-2017, 01:45 PM #5LTx Guru
- 2,279
For some reason, with this site only, when someone posts a link to Summit, and I click on it, it takes me to VigLink, nor Summit. I've seen others complain about this.
@popo8SOLD - GONE TO A (VERY) GOOD HOME ! - 94 Formula A3+1: 381ci forged stroker - Callies Stealth, Oliver 5.85 billet rods, BME nitrous pistons / CNC LT4 heads / CC solid roller / TH400+GearVendors OD / 4.11 Strange 12-bolt / 300-shot N2O / Spohn Suspension / roll bar / MoTeC M48 Pro engine management system /a few other odds 'n ends.
06-08-2017, 01:46 PM #6"The Rock"
@meissen do u know whats happening?
06-08-2017, 02:02 PM #7LTx Guru
- 2,279
First 3 kits are for adding a line lock ONLY. Next 4 kits are for (first 2) - deleting ABS modulator and adding a line lock, while keeping power brake booster; (last 2) - deleted power brake booster, delete ABS, add line lock.
Hurst line lock solenoid is a well-known, reliable brand. I've had mine for 17 years. SJM appears to be a re-branded generic solenoid. Neither of them is "high-tech", just a matter of saving what looks like at least ~80 bucks depending on options on generic.Last edited by Injuneer; 06-08-2017 at 02:06 PM.
06-08-2017, 10:24 PM #83.4L to LT1 Swapper
- Oct 2008
- Brian Meissen
- 1994 Camaro "Red Alert"; 2022 Camaro LT1 RS
- New Haven, MI
- 2,851
- Brian Meissen -
"Magic Man" - LTxTech
The Following User Says Thank You to meissen For This Post:
06-09-2017, 01:37 AM #9"The Rock"
06-09-2017, 08:15 AM #10
I have the Hurst line lock only, one thing make sure you bleed the brakes thoroughly, I bled mine and it worked fine, then at the shootout it would not hold, found out there was still air in the lines, I bought a pneumatic brake bleeder from all places, Harbor Freight and it worked great, My brakes are hard as a rock now..
