Results 11 to 20 of 20
Thread: 275/40-17 vs 305/35-17
05-31-2017, 08:54 PM #11
05-31-2017, 08:55 PM #12
05-31-2017, 09:48 PM #13LTX Regular
- Sep 2015
- Brandon++S
- 1997 camaro z28
- Alabama
- 198
Ok, I've always heard stock rear + sticky tires = broke
05-31-2017, 10:08 PM #14Lurker
- Johnny
- 1994 formula A4
- Henderson, TN
- 935
eventually it will, ive never kept my cars long enough or had enough power to break them.
06-02-2017, 04:28 PM #15Xtreme Member
- Mar 2015
- Mike Storm "Stormy"
- 1995 Trans Am
- Washington
- 1,020
- Blog Entries
- 1
Stock 3.23 here as well for now want 3.73 but the gear god hasnt granted me one yet.
on the phone using Tapatalk
06-11-2017, 11:02 AM #16
Anybody have pictures of the 305/45r17 mounted on wheels? How wide is that tire?
S60 rear
The Following User Says Thank You to Flyinz For This Post:
06-11-2017, 09:10 PM #17"The Rock"
305mm wide.
06-11-2017, 10:59 PM #18LTx Guru
- 2,279
The M/T website data sheet for the ET Street R 305/45-17 shows the measured section width, when mounted on a 10.0" wide wheel is 11.7". Tread width is 10.5". Diameter is 28.1"
06-12-2017, 03:26 AM #19"The Rock"
06-12-2017, 08:00 AM #20LTx Guru
- 2,279
Just a thought...... the section width in the specs is a "nominal" value. 305mm is 12.0", but there is a +/- in the nominal size. The classic example is say the older 315/35-17 Nitto drag radial, that looks OK (maybe a little "bulgy") on a 9.5" wide wheel vs. the same size BFG drag radial that requires a 10.5 to 11.0" wide wheel for the right fit.
Same with the aspect ratio (%). Not a precise number. As a result, the same size tires from different companies, or even 2 different tire models from the same company, can have a slightly different outside diameter than the "calculated" value. Special tires like drag tires, off-road tires, and auto-x tires seem to have the widest variation from nominal size.Last edited by Injuneer; 06-12-2017 at 04:33 PM.
