Results 1 to 10 of 29
Thread: Running Rich and throwing codes
05-25-2017, 04:05 PM #1VIP Member
- Javier
- 1997 Trans Am WS6
- The Final Frontier.
- 735
That didnt take long, LOL
So the WS6 is starting to run pretty rich and idle a little rough, but running decent.
I took my scanner with me and watched it while driving to work.
Yesterday I just got P0151, P0174 and P0400. The P0400 has been going on and off since I put the longtubes. Also I am still running o2 simulators on the downstream until I can install the duals
Today I got P0151, P0400, P1153 and to top it all off, P0300...
I will get some cold and hot idle numbers later on the drive home.97 Trans Am WS6, LT1 factory 4bolt freak, M6,
68 Firebird 400, YC 400, 670 heads M4
14 Fiat 500e, 83kW motor, 24kWh 364 V battery
05-25-2017, 05:26 PM #2Xtreme Member
- Apr 2012
- Cameron
- Dover, De
- 2,076
Sounds like you need some new O2's. The P0300 could be from the O2's being jacked.
Formula Build Thread
05-26-2017, 09:54 AM #3VIP Member
- Javier
- 1997 Trans Am WS6
- 735
I think the O2 did go out, here are my logs:
Cold Engine off, foot on brake
Fuel system status: Fuel system 1: Open Loop (0)
Fuel system status: Fuel system 2: Open Loop (0)
Calculated Engine Load: 0.0%
Coolant temp: 82F
Short Term Fuel Trim - Bank 1: 0.0%
Long Term Fuel Trim - Bank 1: 0.0%
Short Term Fuel Trim - Bank2: 0.0%
Long Term Fuel Trim - Bank 2: 0.0%
Intake Absolute Pressure: 28.9 inHg
Ignition Timing Advance: 0.0
Intake Air Temp: 82F
Airflow rate from MAF: 0.0 lb/min
Throttle pos 0.0%
Bank 1 sensor 1 (O2S) Output: 0.010 V
Bank 1, Sensor 1 Short Term Fuel Trim: 0.0%
Bank 1 sensor 2 (O2S) Output: 0.705 V (simulator)
Bank 1, Sensor 2 Short Term Fuel Trim: 0.0%
Bank 2 sensor 1 (O2S) Output: 0.010 V
Bank 2, Sensor 1 Short Term Fuel Trim: 0.0%
Bank 2 sensor 2 (O2S) Output: 0.695 V (simulator)
Bank 2, Sensor 2 Short Term Fuel Trim: 0.0%
Cold Idle, neutral, foot on brake
Calculated Engine Load: 3.9%
Coolant temp: 84F
Intake Absolute Pressure: 8.9 inHg
Ignition Timing Advance: 18.0
Intake Air Temp: 84F
Airflow rate from MAF: 1.4 lb/min
Throttle pos 0.0%
Bank 1 sensor 1 (O2S) Output: 0.035 V
Bank 1 sensor 2 (O2S) Output: 0.440 V (simulator)
Bank 2 sensor 2 (O2S) Output: 0.800 V (simulator)
Hot Idle, neutral, foot on brake
Calculated Engine Load: 2.4%
Coolant temp: 197F
Short Term Fuel Trim - Bank 2: 0.0%
Intake Absolute Pressure: 8.0 inHg
Ignition Timing Advance: 20.0
Intake Air Temp: 87F
Airflow rate from MAF: 0.9 lb/min
Throttle pos 0.0%
Bank 1 sensor 1 (O2S) Output: 0.820 V
Bank 1 sensor 2 (O2S) Output: 0.425 V (simulator)
Bank 2 sensor 2 (O2S) Output: 0.830 V (simulator)
Hot, engine off, neutral, foot on brake
Coolant temp: 201F
Throttle pos 0.0%
Bank 1 sensor 1 (O2S) Output: 0.810 V
Bank 2 sensor 2 (O2S) Output: 0.440 V (simulator)
also odd is that it didnt go into closed loop.97 Trans Am WS6, LT1 factory 4bolt freak, M6,
05-26-2017, 11:41 AM #4LTx Guru
- 2,279
The code is for a low voltage reading on the passenger side (Bank 2) pre-cat sensor. Appears to be stuck at 0.010 volts. Failed O2 sensor or problem with the wiring, like a short between the tan and purple wires, or purple and black wires.
One way to check.... swap the pre-cat O2 sensors side-to-side. If the code follows the sensor to Bank 1 (P0131), it's a sensor problem. If the code stays on Bank 2, it's a wiring problem.
The sensors and PCM parameters are not all read at the same instant. The PCM sequences through them. It's possible the freeze frame pulled the MAF and some of the other values while the engine was still running, and the remainder an instant later when you turned off the key.
A real continuous log is much easier to analyze than the freeze frames.Last edited by Injuneer; 05-26-2017 at 11:44 AM.
05-26-2017, 11:52 AM #5VIP Member
- Javier
- 1997 Trans Am WS6
- 735
I was gonna swap them this weekend, your post definitely makes me think Im headed in the right direction.
I cant remember how I routed the wires when I put in the long tubes, hopefully its just a bad O2 or the pigtail on the O2 and not the harness...
as far as continuous log vs freeze frames, one of the reason that I bought this app for my phone and not the others is because it claimed data logging, so far I think they mean that it keeps the freeze frame. I sent the developer an email, hopefully the logs are somewhere in there and I jsut cant find them97 Trans Am WS6, LT1 factory 4bolt freak, M6,
05-26-2017, 12:06 PM #6LTx Guru
- 2,279
Did the long tubes require O2 sensor extensions? If so, bought, or made your own?
05-26-2017, 01:54 PM #7VIP Member
- Javier
- 1997 Trans Am WS6
- 735
I do remember talking to Fastbird about extensions, but cant remember if it was for the planned downstream ones, or the ones on the collectors.
I went home for lunch and it went into closed loop and holycow the bank 2 trim went to like 50% and it idled like my weedeater
Side note, whats up with your website Injuneer? I tried to go to your scan data and its giving me 40497 Trans Am WS6, LT1 factory 4bolt freak, M6,
05-26-2017, 02:38 PM #8LTx Guru
- 2,279
My website disappeared several years ago. Buddy of mine was hosting it free, but he lost access to the server.
Do you want the scanner writeup?SOLD - GONE TO A (VERY) GOOD HOME ! - 94 Formula A3+1: 381ci forged stroker - Callies Stealth, Oliver 5.85 billet rods, BME nitrous pistons / CNC LT4 heads / CC solid roller / TH400+GearVendors OD / 4.11 Strange 12-bolt / 300-shot N2O / Spohn Suspension / roll bar / MoTeC M48 Pro engine management system /a few other odds 'n ends.
The Following 3 Users Say Thank You to Injuneer For This Post:
05-26-2017, 03:00 PM #9VIP Member
- Javier
- 1997 Trans Am WS6
- 735
06-02-2017, 12:08 PM #10VIP Member
- Javier
- 1997 Trans Am WS6
- 735
SO, in addition to that, I am getting a P1153, P0154 and occasionally P0303 (and P0300 some times), which doesn't make sense to me since that is Bank#1 cylinder, but all the O2 codes are on the Bank #2
SHEESH.
I am going to pull the O2s this weekend and check them out.
Further frustration is that even though the app I use for OBD2 scanning says it has "datalogging" but its only stored in active memory and cannot be saved or sent, only the snapshot during the code...97 Trans Am WS6, LT1 factory 4bolt freak, M6,
