Results 1 to 6 of 6
Thread: Gear Oil
    Jun 2015
    Ryan
    1994 Camaro Z28
    Minnesota
    Default Gear Oil
    The 4.30s will be going in this weekend. now I run 75W90 Mobile 1. just curious what everyone else runs. we talked about it a little at the bar this weekend and seems like everyone runs something else then the guy next to em.
    LTX Regular
    Nov 2011
    Marc
    1995 Formula
    magnolia, DE
    I just changed the axles in my strange 12 bolt and I'm running lucas 85w 140 with a bottle of gm limited slip differential additive. (Recommended by strange) Don't use synthetic.
    Sent from my A621BL using Tapatalk
    1995 FORMULA M6
    Dec 2011
    Mark
    Altoona, PA
    ^^ X2 I have a Strange S60 and that's what they recommend.
    Apr 2012
    Mike
    96 Z28, 95 Roadmaster
    Conshohocken, PA
    All depends on what the carrier wants. My wavetrac needs dino 75w90.
    all depends on differential guys.
    Dec 2013
    SoCal
    yes depends on Diff. Clutch limited slip you don't use synthetics, Just a GL rated 75-90 dino oil and a 4 ox bottle of GM or Ford friction modifier
    96 BBB 383/T56
  7. The Following User Says Thank You to BALLSS For This Post:
