Results 1 to 9 of 9
Thread: Starting issues
05-02-2017, 10:12 PM #1
Starting issues
So, I have a 94 trans am lt1 m6. I recently lost power to my radio and turn signals, but the hazard lights work. So, I replaced the turn signal flasher and still nothing. I also tested my fuses to see if there was an issue there. I noticed that my radio fuse visually looked fine, but when I used my continuity tester the light was dimmer than all the other fuses. I also unplugged the ground to the battery and noticed with the tester I was still getting power. I proceeded to remove fuse by fuse and still maintained power. Once I plugged everything back in, I went to start the engine and it now only turns over like it is about to start but won't. I double check each fuse to be thorough but still no start. I did as well notice I didn't hear the fuel pump.Any ideas?
05-02-2017, 10:37 PM #2LTx Guru
Confusing comment about unplugging the ground. Are you saying the ground cables (there are two ground wires) were taken TOTALLY off the negative terminal of the battery, no extraneous ground wires there for aftermarket equipment, and you still were able to measure 12 volts at the fuses? Or did you unplug some other ground?
When measuring 12 volts at a fuse, where were you grounding the black tester lead?
http://shbox.com/1/starter_charging_95.jpgLast edited by Injuneer; 05-02-2017 at 10:41 PM.
05-02-2017, 10:41 PM #3
Yes the ground was taken off of the negative terminal. I didn't use a multimeter so not sure what the volts measured. I only used the cheap 8 dollar build tester.
05-03-2017, 08:00 AM #4Xtreme Member
- 7,266
Supporting Memberignition switch is cooked on column I bet
05-03-2017, 01:21 PM #5LTx Guru
Are you saying the ground cables (there are two ground wires) were taken TOTALLY off the negative terminal of the battery, no extraneous ground wires there for aftermarket equipment, and you still were able to measure 12 volts at the fuses?Yes the ground was taken off of the negative terminal.
I didn't use a multimeter so not sure what the volts measured. I only used the cheap 8 dollar build ("bulb" ??) tester.
Since the starter is cranking, it appears that power is passing through the ignition switch, and the PASS-Key system is enabling the starter. Next stpe would be to check for spark while the engine is cranking, then check fuel pressure (he doesn't hear the pump running) and check for the injector pulse with a 'noid light.SOLD - GONE TO A (VERY) GOOD HOME ! - 94 Formula A3+1: 381ci forged stroker - Callies Stealth, Oliver 5.85 billet rods, BME nitrous pistons / CNC LT4 heads / CC solid roller / TH400+GearVendors OD / 4.11 Strange 12-bolt / 300-shot N2O / Spohn Suspension / roll bar / MoTeC M48 Pro engine management system /a few other odds 'n ends.
05-03-2017, 05:18 PM #6Xtreme Member
- Apr 2012
- Cameron
- Dover, De
- 2,076
I just replaced a friends ignition on his w-body Monte. Had the same issue, Car would start normally but no signals, door chime, or RAP. He had replaced the ignition (some chinese ebay knock off), the BCM and frasher switch/relay with no results. I pulled the ignition and could turn the car on just my squeezing the housing. New ignition and the car is perfect again.
Formula Build Thread
The Following 2 Users Say Thank You to Sahara54 For This Post:
05-03-2017, 07:25 PM #7Xtreme Member
- 7,266
Supporting MemberI'm speaking of the ignition switch under the dash ontop of the column, they like to melt and cause weird issies
05-04-2017, 10:45 AM #8
I found three shorts last night in the courtesy fuse, fuse 4 and 3 ( which are headlight something or another fuses). Once I took those fuses out my left and right turn signals were working, but not the hazard lights. Car still won't start. I am going to check fuel pressure and also ignition to narrow it down later today.
05-04-2017, 02:48 PM #9LTx Guru
Fuses 3 and 4.in which panel?
Per 94 Owners Manual, end of dash 3 = HVAC switch, rear defogger; 4 = PCM BAT, Inst cluster, PASS-Key decoder module. Flasher is 2; Courtesy lights are 8; hazard is 6; radio is 17.
If you removed fuse 4, at least one of the PCM power feeds is interrupted.
Under hood box 3 and 4 are each for a headlight door module.SOLD - GONE TO A (VERY) GOOD HOME ! - 94 Formula A3+1: 381ci forged stroker - Callies Stealth, Oliver 5.85 billet rods, BME nitrous pistons / CNC LT4 heads / CC solid roller / TH400+GearVendors OD / 4.11 Strange 12-bolt / 300-shot N2O / Spohn Suspension / roll bar / MoTeC M48 Pro engine management system /a few other odds 'n ends.
