Page 4 of 4 FirstFirst 1234
Results 31 to 40 of 40
  1. #31
    Feb 2017
    N/A
    C4 Corvette
    Thanks again guys.
    And I'll let you know popo8. Thanks for the heads up.
  2. The Following User Says Thank You to pushrodv8 For This Post:
  3. #32
    Feb 2017
    N/A
    C4 Corvette
    Would you guys be able to look at my rotating assembly, I see coolant mixed with oil. I am seeing white discoloration on the bottom of the pistons as well as white spots on the crank.
    also, I see wear pattern from the lifters on the cam, is this normal?
    This is my first real tear down, so I want to double check. This motor is filthy, is coming apart and getting cleaned at a machine shop. The owner appears to have mixed coolant as the passages are gunked up. 140,000 miles.
  4. #33
    Quote Originally Posted by pushrodv8 View Post
    looks like an lt1 with condensation in the oil that sits alot. also, don't be surprised with gunked up coolant passages, dexcool turns to shit after 20 years
  5. #34
    Feb 2017
    N/A
    C4 Corvette
    yeah the car did sit from what I gathered from the previous owner but I paid like $1500 bucks for an immaculate body + rebuilt trans and a car that drove fine but was just tired, so I can't complain.
    Is that cam wear pattern normal? I guess it really doesn't matter cam and valve train is getting replaced.
  6. #35
    If the wheels and lifter bodies look ok, I would say your cam is normal for a cast cam with that many miles.
    Like you said, its being replaced so don't worry to much.
    I would def advise a solid hot tank cleaning of that block.
  7. #36
    as long as none of the rollers or lobes are flat it's fine. I think all the stock cams I've ever removed with 100+k miles looked like that.. that motor looks better than most I've assembled LOL
  8. #37
    Feb 2017
    N/A
    C4 Corvette
    yeah, I have wicked OCD, so I want this baby clean. I have already cleaned the engine bay of all gunk
    My only other concern is all the various block plugs and bolt sizes matched to their location, will the factory service manual list bolt size location(which bolt goes where) for things like the oil pan or heads? I did my best to label and take notes but I want to double check.
    Thanks again for all the help, this is a big under taking as it's my first engine tear down but it's going well so far.
  9. #38
    shbox.com fastener torque matrix will be your friend. there aren't too many different bolts on the motor. it's not bad man. you'll get it.
    make cardboard stencils of things, label directions and punch holes to hold bolts. like oil pan, intake, etc. makes life easy. biggest fear for me was putting rod caps on facing correct direction, and putting a 2nd ring in upside down on cyl 4. but I had a doubt, took piston back out, double checked, reinstalled. just TAKE YOUR TIME, do not rush
  10. #39
    And accept you will have a pile of bolts at the end with no home. Chalk it up to weight reduction.
  11. The Following User Says Thank You to shownomercy For This Post:
  12. #40
    *becauseracevette
