Results 1 to 5 of 5
    Nov 2016
    wayne
    96 pontiac ws6
    Default heater hose and oil cooler
    can i elemanated the heater hoses off the water pump and what is the hose that runs from the pump to the l lower radiator
    Courtesy of Shoebox:
    #16 is oil cooler bypass hose.
    I would "loop" the heater hoses and keep the flow restrictor (#13).
    Nov 2016
    wayne
    96 pontiac ws6
    do you need the oil cooler bypass was replacing the pump and thinking about a vet pump,less and shorter tubes
    1994 camaro
    Lehigh Valley PA
    Quote Originally Posted by busafastone View Post
    you don't need it, but I run it anyway. on the supercharged car we have it capped since it would be in the way
    1994 Z28 T56 - Le2 H/C, SBE, Hooker lt's, some rod ended suspension stuff, and a whole lotta tetanus
    The wrench for LTConvert's 94 Z28- Ellwein 383/LE2 H/C P600B/ CPT Pro Race/Pro Torque 3200
    My heater ports at water pump are welded shut and the oil cooler line was removed, ends are capped.
    ECT sits at thermostat setting.
  6. The Following User Says Thank You to shownomercy For This Post:
