Results 1 to 10 of 33
Thread: Pulse box
04-16-2017, 03:25 PM #1LTX Master
- Jun 2013
- Beaver
- 1994 camaro Z28
- KENTUCKY
- 600
Pulse box
Can someone tell me where the pulse board is.I need the one for the windshield wipers.Ive changed everything on the wipers but it.I cant find shoebox site any more.Does someone know he address so I can check and make its not me/
BEAVER
04-16-2017, 03:36 PM #2Long Live the Opti
- Sean
- 1999 Twin Turbo Corvette
- Fort Wayne, IN
- 12,072
04-16-2017, 03:40 PM #3LTX Master
- Jun 2013
- Beaver
- 1994 camaro Z28
- KENTUCKY
- 600
The pulse bosxfor the wipers.It so your wipers will wipe on hi or low or pulse.I can only get low and pulse.And they only stop in the up position.When I turn them on the come on.Then when I turn the off the will stay in the up position.The will not go to the bottom of the windshiel when turned off.
BEAVER
04-16-2017, 04:30 PM #4LTX Master
- Jun 2013
- Beaver
- 1994 camaro Z28
- KENTUCKY
- 600
I mean pulse board,sorry
BEAVER
04-16-2017, 04:54 PM #5VIP Member
- Dec 2011
- Mark
- Altoona, PA
- 809
Remove this plastic cover on wiper motor. It's the circuit board under the cover.
04-16-2017, 06:59 PM #6LTx Guru
- 2,279
Shoebox is same place it's always been.
http://shbox.com/1/4th_gen_tech1.htmlSOLD - GONE TO A (VERY) GOOD HOME ! - 94 Formula A3+1: 381ci forged stroker - Callies Stealth, Oliver 5.85 billet rods, BME nitrous pistons / CNC LT4 heads / CC solid roller / TH400+GearVendors OD / 4.11 Strange 12-bolt / 300-shot N2O / Spohn Suspension / roll bar / MoTeC M48 Pro engine management system /a few other odds 'n ends.
04-16-2017, 09:32 PM #7Long Live the Opti
- Sean
- Fort Wayne, IN
- 12,072
04-17-2017, 10:49 AM #8"The Rock"
Im pretty ill today, but if Im better 2moro, I will go pull the wiper motor assembly 4 u 2moro from the camaro.
04-17-2017, 03:20 PM #9LTX Master
- Jun 2013
- Beaver
- 1994 camaro Z28
- KENTUCKY
- 600
Thats alright Popo8,After getting the info.i got one and im still having the same problem.I went threw 2 new wiper motor assembly.The same problem still,the wipers wont go into the park position when turned off.a good friend of mine has a corvette that had the same problem.he sent me a process to go threw that fixed the vette.So im going to try it on my camaro and see what happens.Thanks to everyone for the help.
BEAVER
The Following User Says Thank You to beaver50 For This Post:
04-17-2017, 05:27 PM #10Xtreme Member
- Mar 2015
- Mike Storm "Stormy"
- 1995 Trans Am
- Washington
- 1,020
- Blog Entries
- 1
You need power for them to park after turning off switch so ill bet its your switch.
