Results 1 to 10 of 10
Thread: Asbetos
04-14-2017, 08:09 AM #1LTX Member
- Sep 2016
- Brandon Reitz
- 1995 Pontiac Trans Am
- 53
Asbetos
Is this asbetos?
I know this is, only place I have it my house.
04-14-2017, 08:14 AM #2
When was the house built?
04-14-2017, 08:20 AM #3LTX Member
- Sep 2016
- Brandon Reitz
- 53
1915
04-14-2017, 08:31 AM #4LTX Member
- Sep 2016
- Brandon Reitz
- 53
Whats this stuff too
04-14-2017, 11:35 AM #5Xtreme Member
- Mar 2015
- Mike Storm "Stormy"
- 1995 Trans Am
- Washington
- 1,020
- Blog Entries
- 1
Take samples wet the area down get a small sample use protection there (google) places you can have it tested. Do not disturb it get a sample with out much exposer.
04-14-2017, 01:27 PM #6Xtreme Member
- 7,266
04-14-2017, 03:38 PM #7The FABRICATOR!
- Jul 2011
- Chris
- 1985 Monte Carlo SS
- southern illinois
- 7,164
2nd one would be suspect, however seems well encapsulated and if it's not deteriorating or fragmenting it's probably not worth disturbing. Like said above, if concerned have it tested. I have a feeling it's some type of mastic and not asbestos but it's hard to tell in pics
04-14-2017, 07:58 PM #8LTX Member
- Sep 2016
- Brandon Reitz
- 53
Yeah that concerns me because its the duct work, might have to check it out further
04-14-2017, 09:15 PM #9Xtreme Member
- 7,266
Supporting Memberyou do know a)it's on the outside of the duct sealing it and b)if you don't disturb it there's no issue. you need to ingest a LOT of asbestos fibres to even think of causing mesothelioma/cancer. I know many hvac guys with 30+ years in that are perfectly healthy, who repacked boilers back in the day every day for 10 years. that consisted of mixing dry asbestos in water solution and then smacking it in there by hand. if you think they wore dust masks you're wrong.
seriously, it's most likely fine, if it's not disturbed or flaking off. remediation is expensive
04-14-2017, 09:59 PM #10The FABRICATOR!
- Jul 2011
- Chris
- southern illinois
- 7,164
Have someone come out and look at it. They can see the condition better than we can. If it is asbestos but still in good shape, they will most likely suggest to have it encapsulated or sealed and leave it alone. It kinda looks like it has a relatively recent coat of something on it. The asbestos that I'm used to seeing has a more tan/yellowed look, probably from just being older.
