Page 6 of 18 FirstFirst ... 234567891016 ... LastLast
Results 51 to 60 of 176
  1. #51
    Mar 2015
    Mike Storm "Stormy"
    1995 Trans Am
    Washington
    Blog Entries
    1
    Real gassy smell like raw gas and smoke. Check your injectors and your FPR scan should show you something is off.
  2. The Following User Says Thank You to Stormyweather For This Post:
  3. #52
    Quote Originally Posted by superspirit View Post
    I have checked everything that I can think of. including replacing 02's, MAF, map and coolant temp sensor. I am positive it is in the tune, all injectors flow the same in an injector balance test. All plugs are equally covered in black soot.
    As for tuning it myself I am learning how to do that now but more with HP tuners on my OBDII truck. The LT1 blazer is just a toy. and gets close to getting me in trouble everytime I drive it so it's on the back burner till the crewcab camper hauler runs perfect.
    start simple, multiply the maf tables by .95 and see if the blms come down. if the blms are showing rich then you're right, but if they are showing lean and it's dumping fuel based off that that's another issue. like my car, it had a bank 2 lean code since it was stock. I replaced o2 when I put the new motor in, and now that o2 is still lazy at idle cell 16 and goes to 160. since I've tried different o2's, tunes, etc, I'm convinced it is either the wiring or pcm. shit even the no start issue with @Ltconvert car was pcm, no check engine, everything checked fine, swapped pcm and problem is gone.
    op sorry for going off topic, I'll take a look at your log and see if I see anything I recognize as odd
  4. The Following 2 Users Say Thank You to SSlowBoat For This Post:
  5. #53
    If you have a .csv file of a data log, I'll take a look at it. I am NOT a tuner, but I do review data logs for people regularly for troubleshooting.
    @fullforce
    Received your data log. But it's going to take a while just to get it formatted correctly. The TunerPro log has a huge amount of useful data in it, but it has hundreds of unused/empty columns, and the columns are sequenced in alphabetic order, meaning for example "Left" O2 volts, injector pulse width, etc. are somewhere toward the middle of the page, and "Right" O2 volts, pulse width, etc are way over on the right side of the page. Lots of columns need to be hidden, and others have to be moved onto a logical sequence.
    I'm going to work on it, but it won't produce immediate results.
  6. The Following 2 Users Say Thank You to Injuneer For This Post:
  7. #54
    Johnny
    1994 formula A4
    Henderson, TN
    Wow, if its going to be trouble then please dont worry about it.
    I figured since tunerpro is free that most people used it but its probably not as good as the others.
  8. #55
    scan9495 is free and alot easier to use. I've really been liking it lately, especially the ability to switch things on like fans or raising idle rpm with one click.
  9. The Following User Says Thank You to SSlowBoat For This Post:
  10. #56
    Gary has the setup in Scan9495 pretty good... for example cell#, left O2, right O2, left LTFT, right LTFT, left STFT, right STFT, left base pulse width, right base pulse width. And TTS DataMaster allowed you to select up to 30 columns to put in the .csv export, along with the order you want them in. I have a list for the DataMaster suggested setup.
    I WILL take a look. I already hid about 250 wasted columns (a separate column for every OBD-1 code, and every OBD-2 code, for example). I'm moving columns into better groupings. At this point it's a challenge I want to defeat, and maybe find some interesting indications of the problem.
    I only mention the possible delay, because I've run into some people that get pissy when they don't get a fast response. Not even suggesting that is the case here. Last week I did a quick review and offered some comments for someone on CZ28.com, told him I would continue to look at it. I also warned him that I do not have a lot of experience with S/C applications, since he was getting an unexplained high MAP code at idle (boost?). Then he started a new thread because "the other one didn't go anywhere". I questioned that. Then he responded telling me he went there for quick help not having to wait around for 4 or 5 days. As far as I know, he's still waiting.
  11. The Following 3 Users Say Thank You to Injuneer For This Post:
  12. #57
    Johnny
    1994 formula A4
    Henderson, TN
    lol
    Thanks guys, If I ever get a freakin laptop datalogging will be much easier.... I just dont need it for ANYTHING except datalogging witch I wont even do anymore once my car is running fine.
    I had to sit my desktop from my shop in the rear floor and monitor in the passenger seat, all hooked up to an inverter just to get those logs LOL!
  13. The Following User Says Thank You to fullforce For This Post:
  14. #58
    Looked over the driveability file. It's in open loop at the start, target (programmed) idle speed is 800 RPM. Coolant temp is high enough that it is not affecting the targeted idle speed.
    The good:
    - system voltage is healthy.
    - coolant temp steady at about 172 - 176*F. A bit on the cool side, and may contribute to a slight fuel smell in the exhaust if you don't have a cat.
    - system goes into closed loop exactly when it is supposed to at 206 seconds.
    - RPM is within +/- 25 RPM of program value. IAC is a bit high at mid 80's. You only let it idle in open loop. Did not operate at idle in closed loop.
    - TPS is OK at 0.61 volts closed.
    - advance at idle is in the range of 17 - 21-deg.
    The questionable:
    - MAF flow looks high for 800 RPM. What's the LSA on the cam? High overlap can lead to higher than expected mass air flow. For a stock cam, I would expect MAF to be in the range of 6 - 10 grams/second. Yours is about 12.5. My stock LT1 flowed about 6.0 G/S at 800 RPM idle. High air flow results in high injector pulse widths. Again.... about 2 mSec or less expected, vs. 5.5 mSec in your log. Since it's in open loop the Cell 16 BLM's and INT's are locked at 128. O2 readings average 900 mV, which is rich.
    - MAP at idle runs around 55-60 kPa. Cam overlap can account for that. Stock will run 35 kPa. Again, without knowing the LSA it's hard to tell. Could be normal. MAP sensor is OK, since it gets the barometric pressure right.
    The unanswered:
    If I understand the issues correctly, you feel it runs rich at idle. In open loop that is correct. No data for closed loop. You never drove under 53 MPH. But appears the MAF calibration may be a bit off at low flow. Tubby seemed to be on the right track.
    You indicated that there is surge when you hold the throttle steady, with TP% less than 10% and at "parking lot speeds". Above 10% throttle, the RPM seems to be fairly steady. Below 10% there is a slight increase in RPM variation, but you were driving at 60 MPH, not parking lot speeds. Looking at idle with the 8-bit resolution means we can only see changes in 25 RPM increments. You need to look at the 16-bit resolution, but that does not appear to be included in the TunerPro record. I think Gary may even have used that field for something else in Scan9495. DataMaster shows it. Every once in a while there is a quirky number for MAP, or for MAF values, but not enough to suspect any problems with the sensors.
    Advance is very steady at constant throttle position.
    Is EVAP programmed out? The system commands 100% duty cycle a large part of the time, but I can't see anything happening to indicate there is actually any flow. I saw you mention EGR is programmed out.
    You only drove in closed loop in four different cells, out of the 18 available. BLM's:
    Cell 2 - 128 left / 129 right
    Cell 6 - 117 left / 118 right
    Cell 10 - 121 left / 121 right
    Cell 11 - 124 left / 126 right
    I'll continue with the WOT log.
  15. The Following 3 Users Say Thank You to Injuneer For This Post:
  16. #59
    Apr 2012
    Mike
    96 Z28, 95 Roadmaster
    Conshohocken, PA
    I had a similar problem and discovered that my tuner decided to give me an open loop tune even though I asked for closed loop maf. He's quite popular online but his tunes were nothing but problems, so I took the initiative and tuned it myself.
  17. The Following User Says Thank You to Catmaigne For This Post:
  18. #60
    Apr 2012
    Mike
    Conshohocken, PA
    That timing seems super lazy at idle for a cammed car.
  19. The Following User Says Thank You to Catmaigne For This Post:
