Page 3 of 18 FirstFirst 123456713 ... LastLast
Results 21 to 30 of 176
  1. #21
    Quote Originally Posted by MoeHorsePower View Post
    ok, Im getting confused now, Im not doubting you a bit, but I should have your file already but cannot find where I tuned it, what other name could it be under, I dont have anything under fullforce.
    he said his name is Johnny Anderson
  2. #22
    Thanks Tub, Dam I got so confused because I cannot find his name anywhere, and if I sent him a file its probably on the flash drive I lost. I will shoot him an email.
  3. The Following 2 Users Say Thank You to MoeHorsePower For This Post:
  4. #23
    Johnny
    1994 formula A4
    Henderson, TN
    Johnny anderson
    Ls7colorado@yahoo.com
    You shipped it to Henderson, TN
  5. #24
    Did you send me the PCM or did I send you a Bin file? because I cannot find your name and if I sent you a file, then that makes sense..
  6. The Following User Says Thank You to MoeHorsePower For This Post:
  7. #25
    Johnny
    1994 formula A4
    Henderson, TN
    I sent you the pcm
  8. #26
    Yes, I remember now, I found it, Ok, I looked over the file and didnt see anything out of the ordinary, check your FPR and make sure it does not smell like fuel, has the car been sitting? just trying t see if the injectors may be clogged.
  9. The Following User Says Thank You to MoeHorsePower For This Post:
  10. #27
    Johnny
    1994 formula A4
    Henderson, TN
    It was running perfect before the cam swap a few weeks ago. Would datalog logging help any?
  11. #28
    Johnny
    1994 formula A4
    Henderson, TN
    Also it doesn't surge in open loop if that means anything
  12. #29
    Yes, that could be your O2, when in closed Loop what are your O2's doing, are the numbers more at a steady state or are they changing constantly.
  13. The Following User Says Thank You to MoeHorsePower For This Post:
  14. #30
    Johnny
    1994 formula A4
    Henderson, TN
    @MoeHorsePower
    Changing constantly,
    Sending you an Email with a couple of datalogs
