Results 131 to 140 of 176
Thread: leaning out tune?
06-22-2017, 12:50 PM #131Xtreme Member
- 7,266
06-22-2017, 01:17 PM #132Lurker
- Johnny
- 1994 formula A4
- Henderson, TN
- 935
It does smell rather rich at idle but it seems to be idling fairly steady, it will burn your eyes in a few seconds. If in the garage. When driVing the car just acts like it's losing a cylinder or 2 at very very low engine load.
06-22-2017, 01:48 PM #133Xtreme Member
- Mar 2015
- Mike Storm "Stormy"
- 1995 Trans Am
- Washington
- 1,020
- Blog Entries
- 1
Injectors? I'm just saying . Did I all ready ask that?
06-22-2017, 04:44 PM #134Lurker
- Johnny
- 1994 formula A4
- Henderson, TN
- 935
There stock if that's what your asking?
Otherwise if the injectors are bad then they went bad in 1 week while I had the motor down for the cam swap
06-22-2017, 05:04 PM #135Xtreme Member
- 7,266
Supporting MemberI think it's simply some cam surge. with no cats even stock these cars are rich enough to burn eyes. build a boosted 383 with deka 60lb injectors and let me know how bad garage gets at idle.
I think you're overthinking it. drive car, let computer learn
06-22-2017, 05:25 PM #136LTx Guru
One possibility on the smell at idle.....
In Cells 6, 7, 9, 10 and 11 the LTFT's are pulling out fuel (about 9% average). Something is making it run rich, but the LTFT's are able to correct. In idle Cell 16, it appears it's near perfect (130/129), no correction needed. That is a contradiction. If there is blow through at idle due to overlap, or if there is significant misfiring at idle, Cell 16 LTFT's could be misleading. The A/F ratio may still be too rich, and the oxygen in the blow through, or the oxygen in the unburned misfire are going to cause the PCM to falsely increase the LTFT's, based on the O2 sensors reading lean. Maybe Cell 16 is already too rich, like all the others, and the LTFT's are adding more fuel (130.5 relative to average of 116.8 for the other Cells) that the engine doesn't need = smells very rich at idle.
Do you sense significant misfiring at idle?SOLD - GONE TO A (VERY) GOOD HOME ! - 94 Formula A3+1: 381ci forged stroker - Callies Stealth, Oliver 5.85 billet rods, BME nitrous pistons / CNC LT4 heads / CC solid roller / TH400+GearVendors OD / 4.11 Strange 12-bolt / 300-shot N2O / Spohn Suspension / roll bar / MoTeC M48 Pro engine management system /a few other odds 'n ends.
06-22-2017, 05:30 PM #137Lurker
- Johnny
- 1994 formula A4
- Henderson, TN
- 935
Been driving it lol I've put about 1500 miles on it. All im goimg off of is my last car that had almost the same cam on a 112lsa and this one is a 110lsa and I had no missfiring/piping at part throttle.
06-22-2017, 05:36 PM #138Lurker
- Johnny
- 1994 formula A4
- Henderson, TN
- 935
Very hard to tell with the exhaust I have and the chop at idle.
Once I get eehack working again I can do the cylinder cutout and see.
06-22-2017, 06:27 PM #139Xtreme Member
- Mar 2015
- 1995 Trans Am
- Washington
- 1,020
- Blog Entries
- 1
I bought some gasat a out of the way place once cause it said ethanol free. Ran kind opf like what you have going checked my injectors after asking aroundLlong story short I had an injector dumping fuel .fuelk railwould hold prime so did the on car leak test. found it. Doesnt run perfect yet need to cange my O2s still. And now that summer is here wellits on the list.
06-22-2017, 08:01 PM #140Lurker
- Johnny
- 1994 formula A4
- Henderson, TN
- 935
so is there anything I can do on tunerpro to change the fueling down low? if it doesnt work I can always put it back
I tried messing with the MAF in tables 1 and 2 I droped the values by 10% but couldnt really notice any change.
