Results 1 to 10 of 26
04-08-2017, 05:00 PM #1Xtreme Member
- Mar 2015
- Mike Storm "Stormy"
- 1995 Trans Am
- Washington
- 1,020
- Blog Entries
- 1
Mikes (Stormy) oh so low buget build
Ok here goes
Stock LT1 w/ 130K 1995 Tran Am A4
All ready done Large exhaust cat back CAI K&N,trick flow elbow TB bypass Poly Mounts TPis airfoil
My list Engine
Long Tubes and Y and new AC O2'
LE1's heads w/232/240 .578/.574 110 LSA custom cam
and upgrade to Manley 2.00/1.56 valves
while doing the shbox cam while keeping the A/C cam swap
Bosch injectors not sure what ones yet
Stock TB
Stock intake
Maybe a stall converter. Edit 3000 stall but still trying to figger that out personaly
mild build or not
Running gear
Spohn Strange 12 bolt with steel spool and 3.73
big sway bars front and aft with polys
LCA half poly and half ball joint
LCA relocaters
SFC
Service the front end replace all wearoutables
Sport springs or adj coil overs
A big boy racing seat Cause im a big boy 300+
Im just a Marine Tech with single income so tis should be it maybe some custom wheels and fancy stuff later
. I do have a indash DVD with back up cam Double Din do you?Last edited by Stormyweather; 04-10-2017 at 07:42 PM.
04-08-2017, 05:08 PM #2Xtreme Member
- 7,266
04-08-2017, 05:24 PM #3Xtreme Member
- Mar 2015
- 1995 Trans Am
- Washington
- 1,020
- Blog Entries
- 1
Well I know a guy who is a trans guy. you are right the trans she be getting old. What ive got here is a bunch of millennials with mommys WRX.s Or silly stance crap that want to street race. Just raced one today (who runs cars with bright green wheels?) dumb ass. anyway wish this was a 6 speed. Yeah I forgot the tranny. Arnt higher stalls I mean don't they not ingage till you reach the RPM then engage like reving then dropping the clutch?
04-08-2017, 05:45 PM #4Xtreme Member
- Mar 2015
- 1995 Trans Am
- Washington
- 1,020
- Blog Entries
- 1
The trans Dude said 1k to 1500 depending on cam specs for stall I pull no problem. The problem is money. Anyone got any boats that need a fixin? Basicly I mentioned about 6k worth of parts and you know that will grow. ""Marine Tech for Hire""
Todays vocabulary word :Millennials
Millennials are the demographic cohort following Generation X. There are no precise dates for when this cohort starts or ends; demographers and researchers typically use the early 1980s as starting birth years and the mid-1990s to early 2000s as ending birth years. Millennials, who are generally the children of baby boomers and older Gen Xers, are sometimes referred to as "Echo Boomers" due to a major surge in birth rates in the 1980s and 1990s. The 20th-century trend toward smaller families in developed countries continued, however, so the relative impact of the "baby boom echo" was generally less pronounced than the original post–World War II boom.
04-08-2017, 05:51 PM #5
No, its not like dropping the clutch at all. It drives and feels normal it just flashes quicker. Stock stall speed is apprx 1800rpm. You should be looking at minimum a 3500rpm converter. Minimum....
The 3.73s will help make it feel tighter at lower driving speeds. A good quality converter will still retain great drivability on the street.
I ran a FTI lock up converter before i swapped to a 6 speed. It was a great converter.Last edited by Badazz 97 TA; 04-08-2017 at 05:54 PM.
The Following User Says Thank You to Badazz 97 TA For This Post:
04-08-2017, 06:07 PM #6Xtreme Member
- Mar 2015
- 1995 Trans Am
- Washington
- 1,020
- Blog Entries
- 1
Cool thanks didnt know as it is now if I loose traction I go left then right when it shifts to second on street tires but drags isnt all I want. its them pesky WRX's and Evo sunsabitches JKing
04-08-2017, 06:11 PM #7Xtreme Member
- Mar 2015
- 1995 Trans Am
- Washington
- 1,020
- Blog Entries
- 1
04-08-2017, 06:16 PM #8Xtreme Member
- 7,266
04-08-2017, 06:18 PM #9Xtreme Member
- 7,266
Supporting Memberif you want to talk low budget, look for used shit. my entire car I have about 3k in, including buying the car. deals can be found
04-08-2017, 06:26 PM #10Xtreme Member
- Mar 2015
- 1995 Trans Am
- Washington
- 1,020
- Blog Entries
- 1
Wow my Spohn racing list it is a bit over 3k if I could get away with waiting on the 12 bolt I can afford that tranny in 6 to 8 months lol. But hey glad I have modest Expectations. First thing headers I have O2 issues and well car needs to breathe. So looking to save for some pacesetter's Should rename thread to Stormys save o ramma build or Break. Out. Another. Thousand. After all If you own a boat and bring it to a shop.
