Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 41
  1. #11
    Dont Vats keep you from cranking as well.?
    the vats modules can do different things. can not let it crank at all and flash security light, let it crank and kill it after a few seconds with flashing security light, let it crank and kill it with no light, let it crank and crank and crank with no computer pulse to injectors, etc. some do the norm, others do the haywire. IF vats is not tuned out of the pcm, the theft deterrent module, not to be confused with relay, can screw up and not send a square wave signal to pcm telling it to enable fuel pump and run, then computer won't send signal out.
    The issue we just had was either the ground, the theft deterrent module, or bad pcm.
    OP go over your wiring closely. first thing is check that fuel pump does infact prime and hold pressure. if no prime, you have to dig into the wiring more.
  2. #12
    Apr 2017
    Deek
    1976 Pontiac Ventura
    Ohio, USA
    The previous owner put a switch on the dash to turn the fuel pump on; I can manually turn it on and I know it works. Where would the VATS be located? Any way to tell if it or the PCM is bad?
    '76 Pontiac Ventura - "Eileen"
    "Come on Eileen, oh, you know what I mean..."
  3. #13
    Quote Originally Posted by 76Ventura View Post
    see what he has pin a7 going to. red plug on pcm. pin a7 is the feed for pcm to fuel pump relay. if there isn't anything coming from that when cranking then the pcm isn't turning injectors on either
  4. #14
    Apr 2017
    Deek
    Ohio, USA
    I'm going to be fiddling with it tonight. Bringing my voltage tester. What kinda voltage should be going from A7?
    (On a side note, anyone want to trade me my LT1 and trans for a carbed 350 and trans to match? )
  5. The Following User Says Thank You to 76Ventura For This Post:
  6. #15
    key on 2 second 12v prime then zero, have a second person help you
  7. #16
    Apr 2017
    Deek
    Ohio, USA
    Thank you so much for the help, I'll give everything a look and report back with what i find
  8. The Following User Says Thank You to 76Ventura For This Post:
  9. #17
    Apr 2017
    Deek
    Ohio, USA
    Hello, everyone; I have great news. The Ventura fired up and is now running smoothly (after a can of Royal Purple injector cleaner!). It turns out that the injectors weren't firing. After looking around through my wiring, I discovered that my relays were rusty and pretty sketchy looking... lo and behold, change all three of them, and for $20 I got the hot rod running. Thank you everyone for your input, and I look forward to posting around here more often.
  10. The Following 3 Users Say Thank You to 76Ventura For This Post:
  11. #18
    Awesome... very glad u got it goin!
  12. #19
    Mar 2015
    Mike Storm "Stormy"
    1995 Trans Am
    Washington
    Blog Entries
    1
    Yeah great news. and thanks for letting us know as well. most people just ask then there isnt any good news of out come.
  13. The Following User Says Thank You to Stormyweather For This Post:
  14. #20
    Apr 2017
    Deek
    Ohio, USA
    I just wanted to make sure she ran good and didn't stop running before posting good news and jinxing myself... Here's a video of her running.
  15. The Following 3 Users Say Thank You to 76Ventura For This Post:
