Results 41 to 50 of 70
04-03-2017, 01:39 PM #41VIP Member
- Dec 2011
- Mark
- Altoona, PA
- 809
Spec stage 2 plus here. No issues with it.
04-03-2017, 01:45 PM #42Xtreme Member
- 7,271
04-03-2017, 01:48 PM #43VIP Member
- Dec 2011
- Mark
- Altoona, PA
- 809
Maybe go buy just the pressure plate from your local auto parts store and run the disc you currently have.
04-03-2017, 01:55 PM #44Xtreme Member
- 7,271
04-03-2017, 01:58 PM #45"The Rock"
Have u tried Josh or Gail?
04-03-2017, 02:00 PM #46
I have a comp stage 2.5 under under my toolbox waiting to go in, but havent been able to kill the NAPA clutch thats in it. I fought this problem when I first built mine, once I took .-060 off the pivot pedestal I never had another problem.
The Following User Says Thank You to superspirit For This Post:
04-03-2017, 02:02 PM #47Xtreme Member
- 7,271
04-03-2017, 02:05 PM #48"The Rock"
04-03-2017, 02:13 PM #49Xtreme Member
- 7,271
04-03-2017, 04:07 PM #50Xtreme Member
- Online
- Apr 2012
- Mike
- 96 Z28, 95 Roadmaster
- Conshohocken, PA
- 1,869
You don't need that much torque on the pressure plate. Spec is 22ft lb with blie loctite after seating it (do so in a star pattern, make sure it's flat, then torque). I usually torque my arps to 25-30 because I don't trust my torque wrench down that low.
All of the manufacturers use the c70043 china plate now because Valeo doesn't make their mexi pp any more. My spec 3+ is a china plate and so are the street twins.
If your plate was engaging fine before your hydraulics went haywire then the pp is probably still fine.
Sent from my VS986 using TapatalkLast edited by Catmaigne; 04-03-2017 at 04:11 PM.
