Results 21 to 30 of 70
04-02-2017, 05:28 PM #21
if the clutch was working and now it started the issue...sounds like hydraulics failed
I don't have a measurement for the spacer. since you went just the slave on with nuts barely on stud and it still does it...either mc or slave is bad
given what that slave looked like and you having the Tilton MC which had issues you should be good with the stock, new, hydraulics.....unless somehow your PP puked somehow
FWIW I never had a issue with the standard TO or square top one. They both are made offshore96 BBB 383/T56
The Following User Says Thank You to BALLSS For This Post:
04-02-2017, 07:30 PM #22VIP Member
- Dec 2011
- Mark
- Altoona, PA
- 809
Let's think about this. Everything worked fine. Even with welded Rod. Then something happened. Ground the rod down and still have the same issue. Spaced the spacer and still doing the same thing. I'm suspect of something with the fork, pivot T block or throw out bearing. Keep us posted.
Sent from my iPad using TapatalkStock bottom end, Impala head gaskets, Stock heads w/stage 2 port polish Comp beehive springs, Crane 1.6 RR's, Thunder Racing cam, Cloyes Billet True Roller TC, Long tubes, custom true dual 3" w/X-pipe, Ported intake with 58mm TB, 36lb injectors, PCMforless chip, Tick Performance stage 3 M6, Strange S60 4:10's True Trac 35 spline axles, MSD complete Ignition system, Summit electric water pump and a ton of other upgrades.
04-02-2017, 07:36 PM #23Xtreme Member
- 7,266
Supporting Membernothing visibly wrong with any of those 3 man. they all look ok. one thing I did notice is each time you push the clutch the slave comes out and doesn't return to the same spot each time. it seems to stay out .1 of an inch on each pedal cycle. pressure plate looks perfectly fine. throw out bearing looks just as Chinese cheap as it did when it went in. no tearing or bending of lip.
04-02-2017, 07:45 PM #24VIP Member
- Dec 2011
- Mark
- Altoona, PA
- 809
04-02-2017, 07:48 PM #25Xtreme Member
- 7,266
04-02-2017, 09:43 PM #26LTX Regular
- Sep 2015
- Brandon++S
- 1997 camaro z28
- Alabama
- 198
From my experience just be sure to buy the whole unit...master and slave together.
04-02-2017, 09:44 PM #27Xtreme Member
- 7,266
04-02-2017, 10:28 PM #28"The Rock"
04-02-2017, 10:32 PM #29
what TQ did you do for PP bolts when you put the clutch in?
96 BBB 383/T56
04-03-2017, 03:50 AM #30"The Rock"
This is the pic that it looked bent in...
Sent from my SM-G900P using Tapatalk
