Results 1 to 10 of 70
04-02-2017, 12:05 AM #1Xtreme Member
- 7,249
Supporting MemberT56 Fork suddenly hitting and clutch slipping
well, this is a problem I'm having a hard time finding info on. brand new clutch and flywheel, clutch was engaging/disengaging at very top of pedal travel. no issues going into gear. was downshifting blipped throttle, suddenly hear grinding noise, to the point engine stalls. release clutch pedal in gear and car restarts, notice I can't push clutch pedal down more than 1/3 before it grinds I'm assuming the fork on pressure plate.
-i can still shift gears fine, just can't depress clutch more than 1/3 of pedal travel
-clutch suddenly is slipping, it was holding great until this event occurred.
The car has stock hydraulics. is it possible, remotely, that the slave is overtraveling causing grinding, and not releasing all the way causing slip? or should I suspect busted pressure plate?
04-02-2017, 12:16 AM #2VIP Member
- Dec 2011
- Mark
- Altoona, PA
- 809
Try pulling the slave and make sure the pivot ball didn't break. Check clips on fork also. I'm betting something has the fork bound up. Not sure about slave traveling too far. I would think there's something that would prevent that from happening but I've never tried to tear one apart.
Sent from my iPad using TapatalkStock bottom end, Impala head gaskets, Stock heads w/stage 2 port polish Comp beehive springs, Crane 1.6 RR's, Thunder Racing cam, Cloyes Billet True Roller TC, Long tubes, custom true dual 3" w/X-pipe, Ported intake with 58mm TB, 36lb injectors, PCMforless chip, Tick Performance stage 3 M6, Strange S60 4:10's True Trac 35 spline axles, MSD complete Ignition system, Summit electric water pump and a ton of other upgrades.
04-02-2017, 12:18 AM #3Xtreme Member
- 7,249
04-02-2017, 12:25 AM #4VIP Member
- Dec 2011
- Mark
- Altoona, PA
- 809
Don't rule anything out. Our cars are 20 plus years old now.
04-02-2017, 12:27 AM #5Xtreme Member
- 7,249
Supporting Memberyeah true. I would just think that if the pivot broke it wouldn't go INTO gear easily. I can drive it, albeit baby it before it starts slipping, and have no difficulty shifting whatsoever. just can't push clutch more than 1/3 of way down or touch throttle more than 20%.
could a broken throw out bearing be causing the fork to go too far and also be binding up pressure plate fingers, thus causing slip?
04-02-2017, 12:33 AM #6VIP Member
- Dec 2011
- Mark
- Altoona, PA
- 809
That's possible. Seems like the bearings that come with most clutch kits for our cars are cheaply made. Corvette bearing is supposed to be the heavier option. I've had two bearings crack where the fork pulls on the bearing.
04-02-2017, 12:35 AM #7VIP Member
- Dec 2011
- Mark
- Altoona, PA
- 809
The square one is the better of the two.
04-02-2017, 12:42 AM #8VIP Member
- Dec 2011
- Mark
- Altoona, PA
- 809
After some research I guess anything is possible.
04-02-2017, 12:54 AM #9Xtreme Member
- 7,249
04-02-2017, 12:55 AM #10VIP Member
- Dec 2011
- Mark
- Altoona, PA
- 809
Hope it's a simple fix. Good luck!
