Results 61 to 70 of 70
04-04-2017, 08:30 PM #61LTX Regular
- Sep 2015
- Brandon++S
- 1997 camaro z28
- Alabama
- 198
I think that u bolt stiffens everything up.
04-04-2017, 09:01 PM #62Xtreme Member
- 7,249
04-04-2017, 09:15 PM #63LTX Regular
- Sep 2015
- Brandon++S
- 1997 camaro z28
- Alabama
- 198
That old one you pulled was metal I believe, if you ordered a factory replacement the tabs are plastic. That's what I meant by stiffens it up. I think the plastic will flex more, just my thoughts when I did mine.
04-04-2017, 09:16 PM #64Xtreme Member
- 7,249
04-04-2017, 09:18 PM #65VIP Member
- Dec 2011
- Mark
- Altoona, PA
- 809
T56 Fork suddenly hitting and clutch slipping
I don't see it supporting much. IMO.
I would just bolt it on with washers. Your pushing a plunger not the Housing.
Sent from my iPhone using TapatalkStock bottom end, Impala head gaskets, Stock heads w/stage 2 port polish Comp beehive springs, Crane 1.6 RR's, Thunder Racing cam, Cloyes Billet True Roller TC, Long tubes, custom true dual 3" w/X-pipe, Ported intake with 58mm TB, 36lb injectors, PCMforless chip, Tick Performance stage 3 M6, Strange S60 4:10's True Trac 35 spline axles, MSD complete Ignition system, Summit electric water pump and a ton of other upgrades.
The Following User Says Thank You to 1QUICKZ28 For This Post:
04-04-2017, 09:32 PM #66Xtreme Member
- 7,249
04-05-2017, 07:41 AM #67VIP Member
- Dec 2011
- Mark
- Altoona, PA
- 809
04-05-2017, 08:45 AM #68
The only reason they use a u-bolt is so that someone doesn't have to hold a wrench on the other side, you can bolt it up yourself. I've used regular bolts on a stock MC, and both versions of the McLeod MC (the newer one has screw-in studs and nuts) with no issues. I do not have to remove the steering shaft, but it does take some careful angling/finagling to get it around my headers.
The Following User Says Thank You to Spartan7 For This Post:
04-05-2017, 10:45 AM #69Lurker
- May 2013
- 6 speed Impy
- 1991 Z-28, 355, HSR, M6--2005 CTS-V (SOLD)--1994 Impala SS 6 Speed Swap--Have all blocks covered.
- Dover De
- 245
The Following User Says Thank You to 6 speed impy For This Post:
04-05-2017, 10:58 AM #70Xtreme Member
- 7,249
