Results 1 to 5 of 5
Thread: rocker arm hitting head studs ??
03-27-2017, 11:02 AM #1InActive Member
- Oct 2012
- 92 camaro rs ,93 camaro z28
- delaware laurel
- 415
any one ever had rocker arms hit head studs ???
i was using comp 1.6 rocker arms and arp head studs
think going to a narrow body rocker arm should fix it ??
17554880_10210151598121005_535776005_n.jpg17555391_10210151598241008_807342863_n.jpg17579909_10210151598201007_25793083_n.jpg
03-27-2017, 11:54 AM #2
Where is it hitting?
03-27-2017, 12:49 PM #3InActive Member
- Oct 2012
- delaware laurel
- 415
right on the side of the rocker
03-27-2017, 12:55 PM #4
assume you are talking about the head stud rear between the RR...
i run head "bolts" so don't have that issue
You would need to audition another RR to see if the fulcrum body clears. maybe the newer Comp Pro Mags or a "narrow body" RR. The narrow body ones I have used/seen are aluminum though (Crane Gold)96 BBB 383/T56
03-27-2017, 02:15 PM #5Xtreme Member
- 7,266
