Results 21 to 30 of 43
03-30-2017, 05:02 AM #21
that all makes sense tuned Suzuki hayabusa for racing before but first time with car(no more bikes)fist time since carbs i have gone this far with a motor, so having to school myself all over,ever thing you are saying makes sense, now i have to find a good set without braking the bank, i will do some research on the racetronix ones,also found a set on ebay Wholesale Distribution Available for ALL TRE Products!
Visit our eBay Store for all other auctions or contact us and we can create a special listing for you!
You can also contact us at 1-760-586-5617 or Toll Free 877-514-9494 M-F 10-6pm PST
NEW TRE Flow Matched 36 LB/HR Fuel Injectors
Details Shipping Payment Policies Contact
This auction is for one Set of 8 TREperformance Flow Matched 36 LB/HR fuel injectors. These injectors are IN STOCK, on our shelves. You will receive a Set of 8 BRAND NEW Bosch Wide Body style injectors, similar to the photo. The injectors are matched to have only a 3.0% variance, which means you know that you are getting accurate injectors. All TREperformance injectors are tested at our Southern California warehouse on a brand new ASNU flow bench to confirm the flow rates, and typically the system balance is between 1.0% - 3.0%. These injectors are made by TREperformance and come with a 1 year warranty.
Please view the details section below to verify these are the correct injectors for your application
If you will need new OBD1 Bosch EV1 center notch style injector clips they are available in our eBay store for $45 or just contact us if you have any questions and we can create a special listing for you.
Wholesale Distribution available, contact us and we can create a special listing for you!
Details
TREperformance Fuel Injector Guarantee:
TREperformance warranties all of our fuel injectors for 1 year from the purchase date. If you have any problems with your injectors we will test them and replace any defective injectors free of charge. Buy with confidence though, in years of selling these injectors we have seen virtually no injectors fail! If you feel any of your injectors may be defective just contact us via email to receive an RMA number and we will reply back with all the return instructions. No returns are accepted without an RMA number. All of our TRE Fuel Injectors are manufactured according to strict guidelines in order to maintain ISO 9002 and ISO/TS 16949 quality system certifications.
TREperformance manufactures these fuel injectors and we test each injector before shipment. These brand new, recently developed fuel injectors are always in stock and will often ship the day of payment. Save some money and try our TRE Fuel Injectors. We back them with a 1 year warranty! Thank you for considering TREperformance Fuel Injectors!
See this video of us testing some TRE injectors on our ASNU flow bench:
TRE Fuel Injector ASNU Flow Testing
These High Resistance(Approx. 10 OHMS) Saturated fuel injectors will fit many applications, including, but not limited to:
BMW 5, 6, 7, and 8 Series V8 Models
BMW M5, X5 and Z8 Models
Chevrolet Camaro, Caprice, Corvette and Impala
Ford Mustang GT, lx, Cobra 5.0L and 4.6L
Pontiac Firebird and TransAm
Any BMW 8 cylinder model with Bosch EV1 style injectors
Any Ford V8 Engine with Bosch EV1 style injectors
These are Bosch style injectors which work on most top feed Bosch fuel injected vehicles.
Email us if you have questions regarding fitment.
Some vehicles may require fuel rail spacers or electrical connectors.
Specifications:
Condition: 100% BRAND NEW
Typical Flow Rate in LB per hour: 36 LBS/HR @ 43.5 PSI (3 BAR)
Typical Flow Rate in CC per minute: 380 CC/min @ 43.5 PSI (3 BAR)
Actual flow rate of your injectors may vary, but will be matched together
Resistance: 10 ohms (High Impedance, High Resistance)
Voltage: 8-15 Volts, nominal 13.5 Volts
Amperage: 1.0 Amps
Pressure: Min 30 PSIG / Max 100 PSIG
Spacers/O-rings Included: YES, on the injectors
Fuel Delivery: Upgraded Four-hole disc fuel delivery nozzle for superior fuel atomization
Spray Pattern: Four-hole Nozzle With Cone Shape Spray Pattern
Electrical connector type: EV1 (Minitimer, Jetronic)
Overall Length: 3 inches, 74 mm
O-ring to O-ring Length: 2 1/2 inches, 63 mm
Orings: Top and bottom, 14.5 mm
03-30-2017, 07:52 AM #22Xtreme Member
- 7,266
03-30-2017, 07:59 AM #23VIP Member
- Dec 2011
- Mark
- Altoona, PA
- 809
Running GM 36lb here. Believe they were out of a supercharged 3.8. Think I paid $100-$150.
03-30-2017, 09:14 AM #24Xtreme Member
- Online
- Apr 2012
- Mike
- 96 Z28, 95 Roadmaster
- Conshohocken, PA
- 1,865
Avoid TRE like the plague. Notice how they say Bosch STYLE injectors, meaning they are Bosch knock offs. Would much rather have a used set of legit Bosch L67s than those. There's a company in NJ called Fuel Injector Rehab that sells reconditioned and flow matched sets of them for $130-140.
03-30-2017, 09:39 AM #25Xtreme Member
- Online
- Apr 2012
- Mike
- Conshohocken, PA
- 1,865
http://injector-rehab.com/shop/36lb-...-Set-of-8.html
03-30-2017, 12:58 PM #26
Would those in the link work for a 93 LT1?
03-30-2017, 02:15 PM #27Xtreme Member
- Online
- Apr 2012
- Mike
- Conshohocken, PA
- 1,865
If you're talking about the ones that I posted, they will but you have to double up on orings or else they will get pushed out of the rails. Notice how the yellow bosch has 2 orings at the bottom.FIC injector.jpg
03-30-2017, 05:42 PM #28
how about the racetronix 37lbs anyone tried there stuff
03-30-2017, 05:44 PM #29
i am down to those or the gm 36lb 3.8 if i can find a good vendor like catmaigne said injector-rehab
03-30-2017, 05:57 PM #30
Racetronix 01D114x 37# here. I can't comment on anything other than they have worked flawlessly for me for the past 7 years.
The Following 2 Users Say Thank You to Spartan7 For This Post:
