Page 1 of 5 12345 LastLast
Results 1 to 10 of 43
    Nov 2016
    wayne
    96 pontiac ws6
    Default fast injectors was thinking of 36
    have Elliott le1 lt1 set up with cam that should be between 360-380 rear hp was think about the 36 fast injectors
    Nov 2016
    wayne
    96 pontiac ws6
    sorry lt1 stock bottom air gap 52 t/b mid tube headers,ram air no cats magnaflow cat back,t56 trans,410 rear
    Dec 2011
    Mark
    Altoona, PA
    Here's a fuel injector calculator.
    http://www.deatschwerks.com/resource...tor-calculator
    Apr 2012
    Mike
    96 Z28, 95 Roadmaster
    Conshohocken, PA
    36s are more than enough for your build. The FASTs are just reboxed Bosch injectors, pn 0280155888. I doubt they are any different than the standard L67 36lb injectors (also made by Bosch) except the FASTs appear to have the groove for factory style injector retainer clips. You can run the L67 injectors without retainer clips by doubling up on o-rings down by the intake ports. A reconditioned flow matched set of L67 36s can be had for <$150 if you're looking for something cheaper. Look on ebay, part numbers are 0280155811 and 0280155737.
  5. The Following User Says Thank You to Catmaigne For This Post:
  6. #5
    Nov 2016
    wayne
    96 pontiac ws6
    was also thinking of trick flow injectors
  7. #6
    Nov 2016
    wayne
    96 pontiac ws6
    98-02 LS1 Racetronix 33 lb/hr Disc High-Z Fuel has anyone ran these with any luck
  8. #7
    Find out what pressure they are rated at. The LS1 engines run 58psi. If the injectors are flow rated at 58psi, and you run them at the stock LT1 pressure of 43.5psi, they will only flow 28.6 #/HR. I looked at the Racetronix website, but couldn't find that specific injector to find the rated pressure. Do you have a part #?
  9. The Following User Says Thank You to Injuneer For This Post:
  10. #8
    you can easily make a groove with a hacksaw blade, that's what I just did
  11. #9
    Nov 2016
    wayne
    96 pontiac ws6
    01D106x this is from there sight
  12. #10
    Looked specifically at that part # on the RACETRONIX site, does not mention "LS1". Also does not specify the fuel pressure used for the flow test. 43.5psi is the most common, and maybe somewhere on their site they tell you they use that for testing.
    It's the listing on the WS6STORE site that calls them "98-02 LS1....."
    33 lb/hr Disc High-Z Fuel Injector
    List Price: $35.00 per EACH
    Item Code: 01D106X
    Weight: 90.00GM
    Brands: Racetronix
    Manufacturers : Standard Motor Products
    Stock: Yes
    Model: 01D106X
    Categories: Fuel Injectors - High Impedance
    Manufacturer P/N: FJ-SM-41S
    Static Flow lb/hr (n-Heptane): 33.3
    Static Flow Tolerance +/-%: 4%
    Dynamic Flow (mg/pulse): 7.56
    Dynamic Flow Tolerance +/-%: 4%
    Coil Resistance Ohms: 14.5
    Coil Resistance Tolerance +/- Ohms: 0.35
    Spray Pattern: 3-Prong Cone
    Connector Type: Minitimer (Bosch EV1)
    O-ring Type: Viton
    E85 Compatible: Yes
    Methanol Compatible: Yes
    Weight (non-shipping): 0.19
  13. The Following User Says Thank You to Injuneer For This Post:
