Page 1 of 2 12 LastLast
Results 1 to 10 of 17
    Feb 2017
    N/A
    C4 Corvette
    Default Question about LT4 Hot Cam Kit
    I was hoping to get some clarification as I am not getting much help on the vette forums. I don't want to spend thousands on a car that only cost me $2000. As much as LE heads/cam sound nice, if I want big power i'll wait until my C5. I want to breathe a little life into the car, that's all.
    My goal at this point in time is something along the lines of the LT4 hot cam kit. I have a 94 C4 auto. This car is a spare "fun" car to not eat up miles on my new vehicle going to work.
    This kit:
    http://www.jegs.com/i/Chevrolet-Perf...80002/10002/-1
    1. Are all the parts in here good solid pieces? Reading the various forums you get guys fighting you need to lifters, those springs in the kit suck etc etc it's hard to get a straight answer. I already have my motor out to do some tlc(blown head gasket)
    Should I get new springs/lifters/pushrods? If so, would you be able to tell me what would be compatible?
    I will also be doing tune, long tube headers + true dual with x-pipe exhaust, deleting the EGR since the air system won't be following with the headers.
    1994 camaro
    Lehigh Valley PA
    Quote Originally Posted by pushrodv8 View Post
    This kit:
    I would not get the full kit, as the valvesprings are garbage. Just get the cam, find some used rockers or get scorpion sa/crane dual spring kit and enjoy. Hot cam in my bolt on stock longblock firebird was very very fun on street
    1994 Z28 T56 - Le2 H/C, SBE, Hooker lt's, some rod ended suspension stuff, and a whole lotta tetanus
    The wrench for LTConvert's 94 Z28- Ellwein 383/LE2 H/C P600B/ CPT Pro Race/Pro Torque 3200
    I'm sure you will get many different opinions, I am running that exact kit in my LT1. I used the springs the rockers that came in the kit and havent had any problems. I also reused the original lifters and pushrods, again without any problems. I am running a 6 speed and I take it to about 6200 to shift on a hard run.
    I have bought a better set of springs, just havent got around to installing them. I do believe the springs are the weak link in this kit, but again I've been running them without a problem for a couple of years and they were used when I put them in.
    Dec 2011
    Jonathan Englund
    1994 z28/1994 formula
    Nebraska
    As said above the springs are the weak link in the kit. The rest of the kit is fine...
    Sent from my SM-G900R4 using Tapatalk
    LE will sell you just the cam of your choice, and recommend the required valve train.
    http://elliottsportworks.com/?page_id=32
  6. The Following User Says Thank You to Injuneer For This Post:
  7. #6
    LTX Regular
    Dec 2013
    SoCal
    My vote would also be to contact LE for a cam and springs.
    The Hot Cam kit springs were designed for the lighter, hollow, sodium filled springs of the LT4 heads. The LT1 valves are solid and heaver which is why those springs are marginal at best new on LT1 heads
    If you find a deal on just the hot cam you could get the Crane 10308-1 spring kit which is plug & play for LT1 aluminum heads. Put in new valve stem seals when you do the springs. FelPro or good, the Viton ones
    Your stock PR would work...just at high RPM's they will show more flex than thicker wall ones. These Comp PR would be good
    https://www.summitracing.com/parts/cca-7608-16
    1:6 RR. Comp Ultra Pro Mags. The Hot Cam kit uses GMPP made by Crane so Crane Gold aluminum SA's would work well. They are the only RR that will clear stock VC without any drip baffle trimming...although that is no big deal to do if going with the Comp Ultra's.
    You will need a new PCM tune for any aftermarket cam you put in
    96 BBB 383/T56
  8. #7
    Feb 2017
    N/A
    C4 Corvette
    Appreciate it guys,
    I finished pulling the heads today, this engine is wore out and needs a full rebuild. Mixed green coolant and dexcool sludge in the waterjackets. Gasket was broken at cylinder 1. I think the sludged coolant passages didn't help the high temps.
    I might just say fuck it and do a 383. I love the C4 styling, I am just trying to justify cost with modifying an LT1 vs lsx.
  9. The Following 2 Users Say Thank You to pushrodv8 For This Post:
  10. #8
    1994 camaro
    Lehigh Valley PA
    Quote Originally Posted by BALLSS View Post
    Scorpion narrow body sa rockers clear without any trimming or bending fyi
  11. #9
    Appreciate it guys,
    383 would be nice, no one ever wishes they had less cubes. It will make whatever cam choice you end up with that much more driveable, and require much less radical supporting mods to a smaller cube motor (valvetrain, bottom end, converter, gear, etc.) But there's also nothing wrong with just sticking a stock short block in to get it back on the road quicker with less cost.
  12. The Following User Says Thank You to myltwon For This Post:
  13. #10
    Johnny
    1994 formula A4
    Henderson, TN
    Im sure a 24x would be much cheaper than a lsx swap
