Results 1 to 9 of 9
    LTX Regular
    Central Florida
    Default SOLD: 93-97 LT1 F-Body Vortech v1 COMPLETE kit
    Price for EVERYTHING listed is SOLD
    Price for the supercharger kit alone is SOLD
    I have a complete Vortech v1 s-trim polished finish supercharger kit for 93-97 LT1 F-Bodies. You won't find a more complete kit. This kit has been boxed and kept inside since about 2003.
    Kit includes the supercharger, all mounting brackets, bolts, belts, 2 pulleys for high or low boost (7# & 15#, I believe), FMU, bypass valve, oil line, oil pan with drain fitting installed, all inlet and outlet tubes, full instruction/installation manual, modified coolant line assembly with fittings, and pcv hose. I even have the t-rex fuel pump that came in the kit but I don't think I would trust it. Will throw it in though.
    Vortech also included a Crane Fireball HI-6r ignition box in this kit that I am including.
    I also have a blower cam (trying to get specs for it) that was spec'd by Ed Wright, as well as the 1994 computer that is tuned (by Ed Wright) for the entire 355ci combo, the 24# svo injectors that it's tuned for, and a pillar pod with boost and fuel pressure gauges.
    I personally installed the kit on a car that I am rebuilding but the direction of that car has changed and is going back to stock to be sold. I was able to install and run the complete kit.
    It's a v1, so it's loud as expected due to the straight cut gears. There are no pieces or parts missing from the kit and no play in the impeller shaft.
    Shipping is not included in the prices.
    Trades may be considered for AFR or Trickflow heads.
  2. The Following User Says Thank You to OutCast For This Post:
  3. #2
    Dec 2012
    Tommy N.
    Silver 1996 Camaro Z28, Green 1996 Camaro Z28
    El Paso, TX
    Good luck with the sale of only I had the money I would scoop up the kit
  4. #3
    LTX Regular
    Central Florida
    Bump for those with good tax returns, lol.
  5. #4
    LTX Regular
    Central Florida
    Kit is still available. PRICE DROP
    Everything listed for $2700
    Just the supercharger kit for $2200
  6. #5
    Apr 2017
    Anthnoy
    1994 Trans AM
    entertaining any turbo trades?
  7. #6
    LTX Regular
    Central Florida
    Quote Originally Posted by 1988holloway View Post
    I wasn't but send me details and I will put some thought to it. I've been considering it with the price of nitrous fills going up lately.
  8. #7
    Apr 2017
    Anthnoy
    1994 Trans AM
    Thi will pm yo
  9. #8
    Jun 2015
    eric
    1993 TA
    Still interested in the larger crank pulley if you decide to separate it. If its 7" or larger Ill give you $130 shipped for it
  10. #9
    LTX Regular
    Central Florida
    My apologies but I am not interested in splitting up the kit.
