Results 1 to 4 of 4
Hybrid View
    Mark
    Altoona, PA
    Default Help with AJE Racing Spindle Strut Coilovers
    Have this setup for my car. Ball joint boots are torn and I want to replace. Does anybody have any idea how this setup comes apart? Can't find anything online.
    Sent from my iPad using Tapatalk
    10 Second N/A Club
    Josh
    96 Z28
    Holden, MO (KC)
    I wish I could help but I've never seen that setup before.
    -Josh
    co-owner of BDBRacing.com
    NMCA OC 9004
    Mark
    Altoona, PA
    Should have posted. I contacted AJE Suspension Thur Facebook. Apparently I have to take the springs off and then there's a cap to remove the strut cartridge assembly out of the tube. Then I can get to the nut.
    Mark
    Altoona, PA
    Well I finally got new ball joints boots and steering rack boots. Took the time to weigh everything I pulled off and compared to this setup. Knocked 160lbs off the front end with this setup, removing the sway bar, ABS and power steering. Think I may relocate the battery next. That would be another 39lbs off the front.
