Results 11 to 13 of 13
Thread: 95 camaro timing
03-16-2017, 03:34 PM #11
Have not really gotten into all the tables if I don't need to be in it I really don't go in it. I got my first tune from Solomon and have tweaked it from that point in regards to gear changes and adjusting the timing and fueling but other then that have not done much else to it. When I got the car over a year ago it was in deathly bad shape and was running rough. First 1/8 mile pass was 10 sec. but with the tuning from Solomon and tweaking it has gotten down to a 7.96. I figure there is still more there. its a 383 stroker with hot cam, trick flow 23* heads, 52mm tb, long tube headers with full exhaust, 3000 stall converter, 373 gears, air pump deleted.
03-16-2017, 04:59 PM #12Xtreme Member
- 7,266
Supporting MemberHave @MoeHorsePower tune it once, bet it runs better. Not a knock on your tuning, but moe knows his stuff
03-24-2017, 06:01 PM #13
I will probably get with @MoeHorsePower in the near future and have him look at the tune. More then likely will have him do it prior to putting it back on the rollers.
The Following User Says Thank You to red95z For This Post:
