Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Impy dies again
    May 2013
    6 speed Impy
    1991 Z-28, 355, HSR, M6--2005 CTS-V (SOLD)--1994 Impala SS 6 Speed Swap--Have all blocks covered.
    Dover De
    Default Impy dies again
    Hope these are just gremlins I am working out of the system.
    Car died after I got to work a few months ago, 45 miles to Georgetown De, would not start after work, luckily have good friends, guy comes down with a trailer, gets it to his shop wiring harness in steering column fried.
    Now this past weekend drive to the beach, 45 miles or so, car has been running fine the whole time, wont start, fuel gauge is pegged past full, little less than 1/2 in the tank, no buzz and no press at the fuel rail, this is on Sat, Sunday same friend comes with trailer takes it up to his shop to troubleshoot.
    Not sure if I can stand getting stranded again, hate unreliable cars.
    Just venting.
    Mike
    Johnny
    1994 formula A4
    Henderson, TN
    Reliable and 23 year old car dont usually go hand and hand.... BUT, you will figure it out and it might make it another 45 miles or 4500 miles.
    Thats the beauty of not having a car payment and watching your vehicle loose %50 of its value the first 5 years you own it while paying interest...
  3. The Following User Says Thank You to fullforce For This Post:
  4. #3
    U know what im gonna say...
    OWNER/ADMIN
  5. #4
    May 2013
    6 speed Impy
    Dover De
    OWNER/ADMIN
    Yes I know and will more than likely keep it....or use it as ammo against the wife..."well u don't want a CTS-V payment that's why we are waiting for a tow truck", lol
    Mike
  6. The Following 3 Users Say Thank You to 6 speed impy For This Post:
  7. #5
    Dec 2013
    SoCal
    20+ year old cars...stuff finally dies
    no fuel pressure...sounds like fuel pump died....it happens
    96 BBB 383/T56
  8. #6
    May 2013
    6 speed Impy
    Dover De
    Had that problem a few months ago, ended up being wire harness in the column, maybe this time its the pump. I am looking at the racetronix unit for the Impala. I have the hot wire kit already.
    U recommend anything?
    Mike
  9. #7
    Check the connector for the pump and gauge. On the F-Body (I realize you have a B-Body) it's a single connector near the rear axle, with a 12 volt wire for the pump, a signal (resistance) wire for the level float, and a common ground. The fact your fuel gauge is at the max reading probably indicates an open circuit. May be as simple as a bad ground wire, affecting both the pump and the gauge.
    The F-Body has a fuel pump prime connector near the PCM that bypasses the fuel pump relay and the PCM fuel enable system. If the Impala has similar, it's a way to test the pump.
  10. The Following 2 Users Say Thank You to Injuneer For This Post:
  11. #8
    Nov 2008
    1994 Trans Am
    PA, USA
    I hate to hear you're having issues. It is definitely not fun troubleshooting things like this, especially when you like to drive your car long distances.
    CTS-V payments aren't that bad for what you get in return. I am a little biased. haha
  12. The Following User Says Thank You to harner For This Post:
  13. #9
    Dont support him getting a ctsv... lol.
    OWNER/ADMIN
  14. The Following User Says Thank You to popo8 For This Post:
  15. #10
    May 2013
    6 speed Impy
    Dover De
    If u don't mind a few miles there are some awesome deals, and if u don't mind no Recaro's even better But I would need Recaro's!
    I had an 05 V LS-6, so I tasted the LS Kool-Aid, and want more, lol
    Mike
