Results 1 to 10 of 13
Thread: Which nitrous pistons?
02-23-2017, 01:22 AM #1
It's time to order some some pistons. Building a 355 with stock crank, forged eagle I beam rods (5.7), and forged pistons. But which pistons is the question. The plan is to spray a 150 shot (for now) with the direct port wet kit I currently have. After doing a LOT of reading I was set on forged SRP professional pistons, but I'm not sure if they are the best for nitrous. Also looked into Wiesco and Ross as well. All are relatively close in price so just trying figure out which ones to go with. Any advice would be greatly appreciated.
Sent from my SAMSUNG-SM-G891A using Tapatalk
02-23-2017, 07:45 AM #2Xtreme Member
- 7,266
02-23-2017, 10:57 AM #3LTx Guru
You don't want to push the wrist pin too high on a nitrous piston. Typically, they drop the ring pack down on a nitrous piston, to avoid the intense combustion temperatures and to strengthen the piston crown above the top ring, the wrist pin is into the oil ring. You can add ring rails - I have them with 5.85" rods on a 3.75" stroke - but why press the issue. I'd stay with a 5.85" rod. I run BME 2618-T61 pistons, but you don't need or want those for a 150-shot, mostly street-driven application. 4032 is a decent choice, and Wiseco or Mahle are good.
02-23-2017, 01:39 PM #4
02-23-2017, 01:41 PM #5
02-23-2017, 05:15 PM #6
I'm running cp bullet pistons. There nice off shelf piston. I'm running 6in rods in my 355 as well.
94 trans am forged 355, le 21* trickflows, le cam, a4 3800 stall
02-24-2017, 11:50 AM #7
02-24-2017, 05:45 PM #8
02-24-2017, 08:47 PM #9
I'm running the one for 3.5 stroke. Yes spraying them with 200 so far.
02-25-2017, 12:37 AM #10
Awesome, so they work with a 6in rod and 3.480 crank?
