Results 21 to 30 of 34
01-18-2017, 11:55 AM #21
I run my at 28 so far at 10 lbs and have made 710 RWHP turbo, but when I was super charged, at 12 lbs I was at 722 RWHP gapped at 30..Torque with a A4 supercharged was 712, with the turbo it was 675 at 3800 RPM, just so you can compare.
01-18-2017, 01:01 PM #22
01-20-2017, 05:49 PM #23VIP Member
- Apr 2011
- KYLE
- 95 MQBM Z28
- davison michigan
- 3,874
Why you running e98 vs e85? Just curious.
Also what scale you guys using to monitor afr?
01-20-2017, 06:17 PM #24
01-20-2017, 06:51 PM #25The FABRICATOR!
- Jul 2011
- Chris
- 1985 Monte Carlo SS
- southern illinois
- 7,164
You left some on the table at 17°. I run 22° @ 15# with e85. Gas afr of 12:1. When I fatten up to 11.5:1 I start to lose mph quick. You'll hear a lot of guys running 30° on 20+ psi but they usually run in the low 11 afr range. I'd rather stay conservative on the timing and keep the afr lean.
01-22-2017, 09:59 AM #26VIP Member
- Apr 2011
- KYLE
- 95 MQBM Z28
- davison michigan
- 3,874
The afr is close. It's a common misconception but e 98 actually Burns faster than e85 does. But it is harder to light off. You will probably find more power by adding some more timing to it.
I personally would have ran e85 but seen as you said your E85 is testing out to e60 done it was a smart move by going over to the e98.
I know it's an apples-to-oranges comparison but just as a FYI in my naturally aspirated engine my motor has been the fastest at 11.7 AFR. With about 35 degrees in it. Seeing as you are boosted you can take a wild-ass guess and say that you will probably end up in the 11.1 to 11.3 for range maybe even a hair fatter depending on how much you want to turn it up.
I wish I could find my chart for the ethanol fuel stuff and what you should shoot for. It has been a huge help for me at least.
01-23-2017, 10:19 AM #27
Just spoke with my tuner, I was at 11:3 AFR.
And I hated the fact that I couldnt find any E85 as I would have preferred that. So I was weighing the pros and cons for the time being and I hate the fact that I may max out my fuel system before I could get the numbers/ET I want. I have ID1300s and dual intank 450LPH pumps. Takes the car forever to get the car started too. Lol
01-23-2017, 10:23 AM #28
01-23-2017, 11:25 AM #29Xtreme Member
- Apr 2012
- Mike
- 96 Z28, 95 Roadmaster
- Conshohocken, PA
- 1,862
You could always add a content sensor if you're 24x and not worry about what % is coming out of the pump. You would need an OS that's 24x, flex fuel, dbc, with upgraded map. A 411 512kb computer with 12216125 OS (02 Suburban) can do flex fuel and 2 bar but you'd give up RTT. 3 bar w/RTT can be done with a 1mb P59 computer but I've never heard of anyone using that on a LT1, would have to ask Mike @ EFI. Gauges might be tricky to adapt.
01-23-2017, 12:00 PM #30
