Results 11 to 20 of 27
Thread: Spring came apart on new heads
01-16-2017, 10:08 PM #11Xtreme Member
- 7,266
Supporting MemberConsidering ur self aligning roller rockers contacted the retainer and made the locks pop out that would be installer error....so did u put the rockers on?
No reason to break in a roller motor like an old flat tappet cam man...
Also 1/2 a turn seems a little loose, even more loose with how buried that poly lock set screw is, stock rocker studs?
01-16-2017, 10:15 PM #12
Does the first picture of the rocker on #7 exhaust represent the way it ran or have you adjusted it since you tore the engine down? If that's the way it ran, it looks like your pushrods are too short to me. The centerline of the roller appears to be behind the edge of the valvestem.
01-16-2017, 10:15 PM #13
01-16-2017, 10:20 PM #14Xtreme Member
- 7,266
Supporting MemberNo offense, but #1 stock rocker studs are way too weak/short for roller rockers and not meant for them, which brings me to #2 your rockers look to have the geometry all wrong and misadjusted, which will cause a retainer or lock to get fouled up and come apart. You barely had any stud holding the rocker in place man.
Edit: did u reuse the stock head bolts too? They are one time use.
01-16-2017, 10:35 PM #15
01-17-2017, 04:59 AM #16Xtreme Member
- 7,266
01-17-2017, 10:51 AM #17
Def appreciate the time your taking to look at this
Here is pic of springs and under rocker arm http://imgur.com/a/KK2xQ
Also I found the picture of the pushrod install. Here is how it looked when I turned the motor over http://imgur.com/a/ZdPfb
So far It looks like I fucked up the rocker arm install im guessing?
01-17-2017, 10:59 AM #18Xtreme Member
- 7,266
now i can see better on my laptop, damn eyes getting old. you sure there is clearance between the self aligning nubs and the retainer/locks on the ones that are still on? is it possible you over revved or had a lifter fail?
i see nothing wrong with the spring or retainer itself, beside the said damage from the rocker smashing into it some. the valve stems seem to have enough sticking up for the self aligning portion to function without it or the rocker contacting the retainer. only thing i can really think of based off these pictures is a) lifter collapsed b) rockers too loose or c) over rev. if the rockers were loose the sustained 20 mins at 2k didnt help, and i have bumped a sa rocker off while putting a valvecover back on on the drivers side with a lifter that was bled down.2021 Charger Scat 392
01-17-2017, 11:05 AM #19Xtreme Member
- 7,266
01-17-2017, 11:28 AM #20
Hard to tell if there is any clearance or not since motor is still in the car. The rockers themselvers cant move up and down they only move barely left and right.
On the head install I used permatex high performance seal on the threads of the bolts and I put a high temp copper rtv on the front and back of block extending about a 1/2 up the heads
