Results 1 to 10 of 27
Thread: Spring came apart on new heads
01-16-2017, 07:05 PM #1
Trying to figure out who is at fault here. Car was tuned with a mail order tune. I received the heads completely redone with re-machined valves and new springs along with porting. I was told they were suppose to be ready to bolt on. Valve's were set at 1/2 turn past 0 lash. Motor break in went smooth, fired up real strong and did 2k rpms for 20 minutes. Did oil change and a few days later I went to take the car on the road, about 10 min into the drive the low coolant light comes on so I pull over to check things out and im leaking oil badly. Coolants mixing with oil. Pulled off valve cover on driver side and this is what I find.
http://imgur.com/a/uahdx
So what now? Is this just bad luck or is the person who did the heads liable?
Pictures of rocker arm and spring http://imgur.com/a/KK2xQ
Picture of tested pushrod length of 7.150 http://imgur.com/a/ZdPfb
no pushrod on very last valve driver side http://imgur.com/a/bVyecLast edited by LT1Formula97; 01-17-2017 at 06:37 PM.
01-16-2017, 07:46 PM #2
What head gaskets did you use?
01-16-2017, 08:03 PM #3
https://www.summitracing.com/parts/fel-9966pt
Fel-Pro Head Gaskets 9966PT
01-16-2017, 08:04 PM #4Xtreme Member
- Mar 2015
- Mike Storm "Stormy"
- 1995 Trans Am
- Washington
- 1,020
- Blog Entries
- 1
Hell Im betting they are going to say "why didnt you check them out" im guessing. At my work we allways check but thats me I dont trust anyone.
01-16-2017, 08:15 PM #5Lurker
- Jun 2015
- Ryan
- 1994 Camaro Z28
- Minnesota
- 372
shitty situation but I doubt you can get anything outta anyone on this one
01-16-2017, 08:16 PM #6
01-16-2017, 08:20 PM #7Xtreme Member
- Mar 2015
- 1995 Trans Am
- Washington
- 1,020
- Blog Entries
- 1
Coolant in the oil? man head gasket? Crap how did you not frack up the valve or did you?
01-16-2017, 08:47 PM #8
So coolant is a head gasket and no way related to this? Or maybe I need to just get the motor pulled and keep digging. I added a few more pics of the valve tip. Im not sure if it has any damage to it or not looks and feels fine to me but idk there looks like some wear on the tip I guess.
01-16-2017, 08:58 PM #9Xtreme Member
- Mar 2015
- 1995 Trans Am
- Washington
- 1,020
- Blog Entries
- 1
Yeah Id at least pull that head off. But both heads off and check the surface of heads and block. And all of the valves, keepers and such. Plus check that one for straightness. I cant believe you didn't do any damage. Loosing a keeper can happen. always double check smack lightly them with a mallet( little love tap) from the top check , check, check. Heads don't pass coolant thru gaskets am I right? Or is it the Intake that doesn't?
01-16-2017, 09:17 PM #10
I'd chalk it up to bad luck. There's no liability on the shop's part that can be proven. Unless you can directly point to work that they did that caused the failure - which is nearly impossible here - you're on your own. Sorry, man!
Un-needed on a roller engine. Bolt in and go easy for the first 300-500 miles. Done.
The Following User Says Thank You to atlantadan For This Post:
