Results 1 to 10 of 13
Thread: 4l60e help
12-28-2016, 07:05 PM #1
4l60e help
I have a 1994 z28 the trans went out so I bought another from local shop .my transmission has 12 pins in the case the one I bought from the shop has 13 pins in the case will it work in my 94 ? This is the numbers off the one I bought 7chd255h is this a 1994 4l60e my tras mission numbers or 4ffd2. H .will it work or do I take it back?
12-28-2016, 07:38 PM #2Xtreme Member
- 7,266
Supporting MemberNo, it's a newer pwm style, the lock up won't work right and when it down shifts it'll go 4th neutral 2nd instead of 4th-2nd. @Cahall
12-28-2016, 08:17 PM #3"The Rock"
12-28-2016, 08:25 PM #4Xtreme Member
- 7,266
12-28-2016, 09:15 PM #5
No it will not work.
94 trans am forged 355, le 21* trickflows, le cam, a4 3800 stall
12-28-2016, 10:11 PM #6LTXTech Sponsor
- Jan 2013
- Gail C. Cahall
- Newark, Delaware
- 619
Pull the pan on the trans you bought and see if it actually has a PWM solenoid. All aftermarket harnesses have 13 pins because they're universal. The PWM solenoid sticks out of the front of the valve body, on the passengers side. There will be a similar solenoid on the drivers side for 3-2 downshift. You can also look for the letters "PWM" cast in the front of the pump. If it has the letters "PWM" and/or the PWM solenoid, it won't work.
There's a "sticky" in the drivetrain section explaining the differences.
FrankGail C. Cahall
The Following User Says Thank You to CPT For This Post:
12-28-2016, 10:57 PM #7"The Rock"
12-29-2016, 06:08 AM #8
Thanks guys. The one I bought don't have pwm on the front of the pump . I looked up the numbers 7chd and it came out of a 1997 2500 van
12-29-2016, 06:33 AM #9
So if don't have pwm stamped on the pump and don't have the solenoids it will work?
12-29-2016, 09:36 AM #10LTXTech Sponsor
- Jan 2013
- Gail C. Cahall
- Newark, Delaware
- 619
You can't always go by the numbers on the case. 4L60E cases were interchangeable from 1993-1997. The case and internal wiring harness may have both been swapped. If the pump doesn't have the "PWM" stamped in it, it's definitely a non PWM pump. I would just check and confirm on the solenoid. Pull the pan and take a couple pictures and post them. I'll let you know what you have.
FrankGail C. Cahall
