Results 21 to 30 of 75
12-11-2016, 08:21 PM #21Xtreme Member
- 7,249
Supporting MemberI have been to second street, as they tuned a buddies kenne bell cobra. He had two boosted lt1 fbodies in the shop with full motec's. The one he had to move off the dyno, 396 solid roller with advanced inductions stuff. It was NASTY
12-11-2016, 11:23 PM #22LTx Guru
- 2,279
Nasty, as in f'd up, or nasty, as in big HP.
12-11-2016, 11:26 PM #23"The Rock"
12-11-2016, 11:27 PM #24"The Rock"
Ok... well back to part of my original question... can my car be tuned on the stock ob1 converted PCM with double the boost?
I would be more than happy to fly @MoeHorsePower to PA to fine tune the car with the stock "ish" set up for the sake of saying its all still LT1/GM.
OWNER/ADMIN
12-12-2016, 09:09 AM #25Xtreme Member
- 7,249
12-12-2016, 05:57 PM #26The FABRICATOR!
- Jul 2011
- Chris
- 1985 Monte Carlo SS
- southern illinois
- 7,164
12-12-2016, 07:23 PM #27Long Live the Opti
- Sean
- 1999 Twin Turbo Corvette
- Fort Wayne, IN
- 12,072
Larry you're going to run into OBD1 computer limitations if you try to push it.
When I was running the FAST XFI on my car, I was still opti and single coil. I presume that's where you want to stay. Everything worked, even the two step feature of the XFI. The Holley systems will be the same way. Megasquirts are nice, cheap, but there's a learning curve and a lot of DIY involved.
Wiring in the XFI wasn't bad. Only about 30 wires cut off the PCM and spliced into the XFI piggyback harness I had. This will hold true to all aftermarket systems. You need the stock PCM intact to run the dash stuff unless you go full crazy and swap in aftermarket gauges in the dash too.
12-12-2016, 07:28 PM #28Xtreme Member
- 7,249
12-13-2016, 08:47 AM #29
The Following User Says Thank You to MoeHorsePower For This Post:
12-13-2016, 08:53 AM #30"The Rock"
