Page 2 of 8 FirstFirst 123456 ... LastLast
Results 11 to 20 of 75
  1. #11
    How difficult is the holley efi system to integrate?
    OWNER/ADMIN
  2. #12
    LTXTech Sponsor
    Jan 2013
    Gail C. Cahall
    Newark, Delaware
    Larry, yes. We would get you a billet 9.5" converter for it.
    Gail C. Cahall
  3. The Following 3 Users Say Thank You to CPT For This Post:
  4. #13
    Quote Originally Posted by Cahall View Post
    THANKU FRANK!!!
    OWNER/ADMIN
  5. #14
    Several people I know, plus myself have had good luck with the MoTeC line of ECU's. State of the art, and they can accept the Opti cam position sensor input, so you can keep the Opti and run 8 LSx coils. The ECU's work great with forced induction. Add to this the advantage that the guys at Second Street Speed in Perkasie, PA are authorized MoTeC installer/tuners, and have built and tuned successful 1,000+ HP FI LT1's.
    http://www.motec.com/m1-series-overview/m1s-overview/
    Then there are steering wheels available.....
  6. The Following User Says Thank You to Injuneer For This Post:
  7. #15
    What if i dont want to run ls coils. I really want it to be an opti run vehicle still.
    OWNER/ADMIN
  8. #16
    The FABRICATOR!
    Jul 2011
    southern illinois
    You can use the opti low res signal as a crank trigger and still run the high voltage through it, but that's the extent of it. To my knowledge there is not an ecu on the market that uses both the high and low res signal from the opti.
  9. #17
    What about the micro/mega squirts?
    OWNER/ADMIN
  10. #18
    The FABRICATOR!
    Jul 2011
    southern illinois
    Unless you are planning on running sequential injection you don't need the high res signal. Most aftermarket ecu have sequential capability but few use it. You would just run batch-fire injection where it would fire one bank at a time.
  11. #19
    The FABRICATOR!
    Jul 2011
    southern illinois
    OWNER/ADMIN
    I believe the megasquirt only uses the low res signal.
  12. The Following User Says Thank You to firebird_1995 For This Post:
  13. #20
    The MoTeC uses both high and low res signals, and runs full sequential.
