Page 4 of 4 FirstFirst 1234
Results 31 to 39 of 39
  1. #31
    Oct 2014
    Justin
    1995 Formula
    Houston, TX
    K-member, LS brakes, LS rack, and Viking DAs got installed last weekend. Just gotta align it and get the brakes to clear my pro stars and hopefully, it'll be ready for its first 10 sec pass.
    95 Cyber Grey Formula
    396 M6
    LE 244/252 .636/.636 110
    LE 215cc Trickflows
  2. #32
    Oct 2014
    Justin
    1995 Formula
    Houston, TX
    Update: Made a few passes last night. Unfortunately, I was there for 5 hours and only made 3 passes. 2 of which I missed a gear.
    The good news is, the car is extremely consistent on launch. It's just not very fast yet.
    It dead hooked every time with zero wheel spin. Even at 18 psi and a 5k dump and all 3 passes were 1.7x 60 ft. Not sure what else I can do to launch it harder other that leave off the limiter or bump the tires up to 20 psi.
    My only good pass was the first one, which I didn't run very hard because I wasn't sure how the suspension was going to react. It was 1.7x, 11.8@117. I'm confident if I shifted faster I could hit 120 again.
    396 M6
    LE 215cc Trickflows
  3. #33
    Jun 2015
    Ryan
    1994 Camaro Z28
    Minnesota
    how was the track
  4. #34
    Oct 2014
    Justin
    1995 Formula
    Houston, TX
    It didn't spin at all on a 5k dump so I gotta say it was pretty good.
    396 M6
    LE 215cc Trickflows
  5. #35
    Oct 2014
    Justin
    1995 Formula
    Houston, TX
    Pulled off a valve spring and had it tested. was sitting at 36xlbs open and specs call for 400+ so it's ready to be changed. Doubt it's gonna make a huge difference but every bit counts.
    396 M6
    LE 215cc Trickflows
  6. #36
    Oct 2014
    Justin
    1995 Formula
    Houston, TX
    Got them all changed yesterday. It seems to be running smoother. Although it could just be a placebo effect. Gonna put it on a dyno Monday or Tuesday to further diagnose the issue. I have a feeling the stock WS6 intake with WS6 hood with the baffles still in may be robbing a few hp. I'll try running it with the hood open and closed and again with the airbox top removed.
    396 M6
    LE 215cc Trickflows
  7. #37
    Oct 2014
    Justin
    1995 Formula
    Houston, TX
    I think I found the problem. Although it may be too early to tell. I replaced my coil and found a vacuum leak to the opti. It now idles smoother an the butt dyno had responded very well all the way to the rev limiter. I'll update again after the dyno.
    396 M6
    LE 215cc Trickflows
  8. #38
    Jul 2013
    Alex Rauld
    1994 Trans Am GT
    Awesome glad to hear you possibly fixed it.
    BTW what size afrs do you have on that motor?
  9. #39
    Oct 2014
    Justin
    1995 Formula
    Houston, TX
    Originally they were 195 but I had them ported locally and can't remember the size now. 205ish I think
