Results 1 to 10 of 20
Thread: Six Speed Swap Kits???
10-08-2016, 06:18 AM #1"The Rock"
So hypothetically speaking. Does anyone know if there is a kit to swap a 6spd into a b-body, if u have everything from a "donor" fbody?
Ie; mounts... etc.
OWNER/ADMIN
10-08-2016, 06:49 AM #2LTX Regular
- Online
- Nov 2011
- Marc
- 1995 Formula
- magnolia, DE
- 400
Hmmm.... I like where this is going.
Sent from my A621BL using Tapatalk1995 FORMULA M6
The Following User Says Thank You to 95 blackbird For This Post:
10-08-2016, 07:08 AM #3Xtreme Member
- 7,249
Supporting MemberThere is, i will send you links. Requires some cutting for pedals
10-08-2016, 07:29 AM #4Xtreme Member
- 7,249
Supporting Memberhttps://threepedals.com/conversion-k.../#.V_jh0tApDqA
Thats full kit. A few guys have used it
http://www.f2bkit.com
Thats conversion for pedals
http://www.bigfastcar.com/orderOnline.asp
Idn if ^ josh is still making the kits, i would try calling him
http://www.clearimageautomotive.com/...ss_members.php
Crossmember
Theres an install pdf on the grail from mike fetko that i texted you. Basically, it would be really easy for chris to swap it considering you have a full parts car there with just the f2b kit.
http://cloud.tapatalk.com/s/57f8e6a9...ll%20guide.pdf
10-08-2016, 08:26 AM #5"The Rock"
Thanku sir... wow!
OWNER/ADMIN
10-08-2016, 09:53 AM #6Xtreme Member
- 7,249
10-08-2016, 09:55 AM #7Xtreme Member
- 7,249
Supporting MemberAnd chris could even mod the factory impala crossmember with a little grinding and welding. Plenty of pics online on how to do it. Then its a simple cut in the floor for shifter, and console mods are minor to make it look factory.
10-08-2016, 10:12 AM #8Xtreme Member
- Apr 2012
- Mike
- 96 Z28, 95 Roadmaster
- Conshohocken, PA
- 1,862
Gma has the f2b kit and Clear Image crossmember
10-08-2016, 09:42 PM #9"The Rock"
Awesome info... so is it not worth me saving the pedal assembly from the camaro?
OWNER/ADMIN
10-09-2016, 09:37 AM #10Xtreme Member
- Apr 2012
- Mike
- Conshohocken, PA
- 1,862
The f2b kit uses the fbody pedals (f 2 bbody) so definitely keep them. I know the kit is a ton cheaper than some of the others.
