Page 30 of 82 FirstFirst ... 202627282930313233344080 ... LastLast
Results 291 to 300 of 820
  1. #291
    Mar 2015
    Mike Storm "Stormy"
    1995 Trans Am
    Washington
    Blog Entries
    1
    I'm only buttin cause somehow taptalk has me following. But is it lowered and by that meaning dose it change pinion angle? And would that affect it?
  2. #292
    Stock suspension, albeit 200k mile old. Has stock torque arm and bracket. Haven't had the money for an adjustable yet. I plan on getting one to correct that to begin with. But this feels alot worse than pinion angle. It literally makes the knock sensor spaz
  3. #293
    Mar 2015
    Mike Storm "Stormy"
    1995 Trans Am
    Washington
    Blog Entries
    1
    You had this before the new shaft? Didnt see anything broken like mounts. Checked the shaft for balance new and old. Shit when shit goes wrong I sometimes just put back what i did. 90% of shit that goes wrong after is mostly my fault. Someting I did wrong or bad part.
  4. #294
    Sep 2014
    Joel
    Colorado
    Following popo8 lead spitballing have you looked to see if there is something wrong with the tire ( separate cords in the tire bubble in the side wall, tread separation from the cords.)
  5. #295
    It did this before with everything stock. Now I have poly motor and trans mounts, good aluminum driveshaft, and it's doing it the same as before, hence why I believe it's something out back. If i can get the wheels on tonight then I'll see if it's that. Tires have no bubbles.
    If it was pinion angle it would usually do it more when accelerating vs decel and vice versa. I have been thru that when I rushed my umi torque arm install on my old formula. This is consistent on either.
    If it was worse id blame it on poly mounts. But that's all I ever run, and they've never caused this.
  6. #296
    Sep 2014
    Joel
    Colorado
    I have had the vibration occur once and it happened to be the drive shafts out of balance.
  7. #297
    Fyi... when i lowered the camaro... it had a pinion angle vibration from 80-85 only. So dont rule anything out.
    OWNER/ADMIN
  8. The Following User Says Thank You to popo8 For This Post:
  9. #298
    OWNER/ADMIN
    yeah, im still searching for an adjustable torque arm on the cheap before dyno day. either that or get the founders one, but funds is tight. need another firearm? lol
  10. #299
    Ill sell u the one on the camaro if u wanna come remove it.
    OWNER/ADMIN
  11. #300
    Wait. Nevermind
    OWNER/ADMIN
