Results 11 to 15 of 15
Thread: Line lock
10-21-2016, 10:30 AM #11LTx Guru
Probably be a good idea to download the factory manual with regard to bleeding the complete ABS system.
http://www.firebirdnation.com/forums...2-wiring-diag/SOLD - GONE TO A (VERY) GOOD HOME ! - 94 Formula A3+1: 381ci forged stroker - Callies Stealth, Oliver 5.85 billet rods, BME nitrous pistons / CNC LT4 heads / CC solid roller / TH400+GearVendors OD / 4.11 Strange 12-bolt / 300-shot N2O / Spohn Suspension / roll bar / MoTeC M48 Pro engine management system /a few other odds 'n ends.
10-22-2016, 06:10 AM #12
Thanks Injuneer. The only other thing I heard is it could be the valve in the master cylinder
10-24-2016, 09:54 AM #13LTx Guru
Sometimes it's necessary to "home" the ABS motors, as mentioned in earlier posts. I believe this can be done with Scan9495, eliminating the need for a Tech-1/Tech-2. I know #GaryDoug has tested it with the 96 ABS system. 97 should be the same???
10-25-2016, 09:36 AM #14
So scan9495 can set the abs off for bleeding them?
10-25-2016, 04:29 PM #15LTx Guru
It can "home" the motors, which is the first step in bleeding the brakes. But, typically you only need to home the motors if there were ABS codes set.
